DarshanJ
Nov 13, 2026 9:49 AM UTC
Unable to drag layers into a group in the Layers panel
Hi Figma team,
I'm experiencing an issue with the Layers panel. I cannot drag and move layers into an existing group.
For example, I have a text layer outside a group. When I try to drag the text layer into the group using the Layers panel, it doesn't allow me to drop it inside the group.
I have already tried:
  • Refreshing Figma
  • Restarting the browser/app
  • Testing in a new blank file
  • Trying to drag different layers and objects
However, the issue still persists.
Normally, dragging a layer into a group should change its position in the layer hierarchy, but this is not working for me.
    Karuna Tata
    Nov 13, 2026 10:28 AM UTC
    Hello,
    • When you drag a layer over the group, do you see a blue insertion indicator, or does nothing happen?
    • Does the issue occur when the group is expanded as well?
    could you try copying the layer, selecting a layer inside the target group, and pasting it to see whether that works as a temporary workaround?
    Syed Wajeeh
    Nov 20, 2026 1:30 PM UTC
    just faced the same issue but i fixed it, my ram was hitting its limit so i just closed some tabs and and programs and its working fine now
