Rishabh soni
Dec 24, 2025 7:22 AM UTC
UI stuck
there is a senerio where enter Key stopped working.
CTRL + / (Open actions) → Tab (it does not do any thing) → press enter key 🔥
Highlighted topic or option does not get activate.
    Dec 29, 2025 3:06 AM UTC
    Hi ​@Rishabh soni,
    I understand that in the Quick Actions menu (Ctrl + /), pressing Tab doesn’t move focus, and pressing Enter doesn’t activate the highlighted option.
    On my end (Mac), I tested opening Quick Actions using Cmd + / as well as Cmd + K, which is the shortcut documented in the Use the actions menu in Figma Design.
    I also noticed that the Tab key doesn’t switch between tabs (All / Assets / Plugins & Widgets). However, pressing Enter still opens the highlighted option. So far, I haven’t been able to reproduce the same issue.
    To cover the basics, could you please try the following and see if anything changes?
    • Close any Figma tabs you’re not currently using.
      • Browser: Force-quit your browser and open Figma in a new window.
      • Desktop app: Force-quit the Figma desktop app and restart it.
    If the issue persists, could you also let us know:
    • Does this happen in the desktop app, browser, or both?
    • Does this occur in a specific file, or across all files?
    • It would also be very helpful if you could share a screen recording with a keystroke visualizer enabled. This will help us clearly see which keys are being pressed and better understand the behavior.
    This information will help us determine the best next steps.
