KarimT
Mar 27, 2026 10:38 AM UTC
Trouble getting the Figma Desktop MCP integration to connect with Claude.ai
Hi,
I'm having trouble getting the Figma Desktop MCP integration to connect with Claude.ai.
Setup:
- Latest version of Figma Desktop (macOS)
- Desktop MCP server enabled in settings
- Image source set to Local server
- Iceberg Master file open with a node selected
Issue:
The MCP panel in Dev Mode shows 'Session activity: Not sent' — the session never establishes. When I send a prompt to Claude.ai referencing a Figma node URL, Claude's tools return 'No result received from client-side tool execution' every time.
What I've tried:
- Restarting Figma Desktop
- Re-enabling the MCP server
- Selecting different nodes before sending prompts
- Starting new Claude.ai conversations
- Signing out and back in to Figma Desktop
None of these resolved the issue. The session activity remains 'Not sent' throughout.
Could you help me understand why the session isn't being established and how to fix it?
Thank you
    Mar 31, 2026 12:24 AM UTC
    Hi ​@KarimT,
    I understand you're having trouble with the Figma Desktop MCP server connection to Claude.ai.
    I can see that you've already submitted a support ticket(#1805734) about this issue, so I've added a note mentioning that you also reached out on the forum to help prioritize your case.
    It looks like a specialist working on your ticket has already replied to your support email.
    They've requested a few additional items (such as a screenshot of the issue and your client details), so please check your email and respond when you get a chance.
    Thanks!
    Matt Hagerty
    Apr 9, 2026 7:22 PM UTC
    Any update on this? I’m facing this issue as well.
    adamsmasher
    Apr 10, 2026 10:04 PM UTC
    Hey ​@Matt Hagerty!
    Thanks for your reply. That’s unfortunate that you also ran into this.
    Are you using this with Claude.ai in a web browser, or are you it with Claude Code in the Claude desktop app or an IDE (VS Code, Cursor, etc)? The desktop MCP server is meant to be used with an MCP compatible client rather than through the web app. If you are using it through a compatible client, what do you see when you type /mcp after starting a session with Claude? It will tell you if the Figma MCP is installed and whether it’s connected.
