Andrews Joseph
Oct 18, 2026 5:53 PM UTC
Too high AI credits used for creating a plugin, even for all failed attempts, and final out is unusable
I was trying to create a simple plugin with the Figma Agent after having viewed your tutorial on how to create generative plugins with the Figma Agent. Unfortunately I lost total 2500+ AI credits, i.e. I had balance of 3242 AI credits before giving the prompt for creating the plugin.
After 3 unsuccessful attempts by the Agent (each time the generated Plugin threw up errors which did not make sense, but still consumed a lot of AI) each generated version never gave me a proper output wherein I could use the plaugin. My AI balance reduced from 3242 to 690, which is a total of 2,552 credits being used for an output plugin which is a complete waste of time & credits.
I request the support team to please look into this issue, and reverse my AI credits balance.
Thanks & Regards,
Andrews
Tom Reem
Oct 18, 2026 8:53 PM UTC
Hi ​@Andrews Joseph, welcome to Figma Forum and thank you for taking the time to lay this out.
This is worth a closer look. Since each version of the plugin threw errors, I’ve connected you with our Technical Quality team so they can dig into the plugin issue and the credits used. I’ve opened case: 2204836, and emailed you with steps for sharing your file securely.
For reference, these articles cover how generative plugins are built and tested with the Figma agent, along with best practices for AI credits:
Again, thanks for your report and for your patience as we follow up on this. 🙏🏻
Andrews Joseph
Oct 22, 2026 1:48 PM UTC
Hi Tom,
Thanks for your prompt reply and the follow up.
Unfortunately I cannot share the figma file or the screenshots, due to security reasons of the company. I’m working behind a VDI, and cannot share anything outside of this network.
At the most I can give you the ticket number of the generated plugin, if that can help you analysis & rectify this issue. y AI credits have gone so low due to this 1 plugin, I’m no longer able to use the Figma Agent. If possible can you identify this error of high usage of the AI credits and reverse back the extra addiitonal credits that have been erroneously charged to my Figma account. Btw I’m on a corporate enterprise Figma license. Just 1 confirmation I want to make, the Plugin generation in the 1st instance and thereafter the 3 iterations did not generate errors while publishing the plugin, but each generated plugin version was full of erros and un-usable, and in every iteration I asked the Figma agent to fix the errors, which should have have costed this much of credits as it was just to fix errors, but it ran the whole process all over again each iteration and charged almost equal aount of credits as the 1st initial plugin generation.
The final plugin generated also has many erros and is still not usable
Would really appreciate your help & support in identifying this.
Best regards,
Andrews D
ksn
Oct 22, 2026 8:23 PM UTC
Hey ​@Andrews Joseph - stepping in for Tom to help!
First, completely understand that there are security guidelines you must adhere to. We can help while working with that requirement.
I reviewed your case and saw that the support ticket Tom filed for you was assigned to someone on our Technical Quality team, who reached out to assist you.
Could you confirm whether you received Tom’s initial email and the follow-up from support? As moderators, we have limited access to the information needed to investigate and fully resolve your request, so our support team will need to work with you directly.
