Omar Mainuddin
Jan 12, 2026 5:34 AM UTC
The selection command "Select all with same text properties" deselects instead of selecting the desired text layers
I’ve noticed this happening for the past month or more, where every other selection command works as intended, instead of “Select all with same text properties”. This has been happening across 2 different Figma Pro accounts as well, so I was wondering if anyone else faced the same issue, and if there is any solution or alternative to performing the same action. It’s a command that I use often, so I would hope there is a hot-fix as well 😃
Thanks, and cheers.
Brian B
Jan 15, 2026 11:55 PM UTC
Yes! This has been happening to me and it’s maddening. Every now and again it will select a small subset of the same type style, but more times than not it deselects everything.
Jan 23, 2026 7:15 PM UTC
Hi All, thank you for flagging this issue!
Our team confirmed that this is a long-standing bug that they’ve been trying to investigate and fix. While I don’t have an exact timeline to provide on the resolution, please know that this is on the team’s radar.
If we receive any updates from the team, we will be sure to update this forum topic.
