Alex Podstreha
Oct 1, 2025 10:22 PM UTC
The Alt key for measuring distances doesn't work
The problem occurs in both the desktop app and the web version
My friend has the exact same issue
I have already disabled all GPU overlays
Windows 11 pro
Junko3Solution
Oct 2, 2025 1:53 AM UTC
Hi there,
Thanks for flagging this! Our engineering team has released a fix for this issue. Could you please refresh your tab and try to use the shortcut again to see if this is now working?
Thanks again for bringing this to our attention, and for your patience while we worked on the fix!
장영빈
Oct 1, 2025 11:59 PM UTC
same
homeru
Same
KirillBD_from_dZPDE
Oct 2, 2025 12:01 AM UTC
When selecting one of the objects, I want to view the distance in pixels to another object by pressing the Alt button. However, copying the element is enabled instead, rather than checking the distance in certain numbers. How can I fix this issue? I paste the screenshot.
bd.
Rogério Paes
Oct 2, 2025 12:19 AM UTC
Same - using MacOS
4mation
Oct 2, 2025 12:27 AM UTC
I just installed the latest version of Figma, and it seems that the “Measure to selection” shortcut/function doesn’t work anymore
What I’m referring to is when you select one object, then hold option key + hover over 2nd object to see the distance between the two objects - this doesn’t seem to work anymore. Instead of showing the distance, it’s showing the duplicate object icon…
Is this happening to anyone else?
MattTG
Oct 2, 2025 12:30 AM UTC
Same here, not working
MattTG
Oct 2, 2025 12:37 AM UTC
Heelllllllp @figma
yassadi
Oct 2, 2025 12:39 AM UTC
Same issue on Windows
Dominic_See
Oct 2, 2025 1:00 AM UTC
Sonia14
Oct 2, 2025 1:08 AM UTC
