Meredith_Ford
Aug 15, 2025 4:32 PM UTC
Text property changing text style
I have a component for a quote box with two variables (large and small). The quote text box has a text property applied (so that if I change the copy, it stays the same when I switch between variants). I did have the text in the large one set to a larger text style than the small one. But now, when I try to edit the text, it changes the text styles in both versions to match. I want to be able to have the text that is in them linked, but not the text style.
This has been an issue since the latest update.
Alex Clanfield
Aug 24, 2026 2:00 AM UTC
I’m just encountering this too when creating new components - i have a file with some old ones where this isn’t happening so can see what its supposed to be doing and does already- not multi-editing
Christoph12
Sep 3, 2026 4:18 PM UTC
For me it also occurred today with a new component. With the old component on the same page, it doesn’t happen. In my new component, as soon as I apply the same text property to the text element in all component variants, the font styles and text colors of all text element are becoming the same in each variant.
Christoph12
Sep 3, 2026 4:26 PM UTC
Okay, I found a workaround in my case:
I detached the text property from my text elements (throughout all my variants). Then I deleted the text property completely. I created a new text property directly on the component (first being not linked to any text element). I gave it a different name from the old one, just to be sure. Then I selected my text elements again and applied the new text property. Now they all kept their inherent font styles and text colors.
(I realised this, because before my fix, when I applied the text property to my text elements, the font styles were not defaulting to one of the elements’ font styles, e.g. like to the first one’s style, as if the text property just syncs the font styles in addition to the text content. It actually applied a different font style to all the text elements which I have tried out before. So I assume that when I created my original text property, a font style -- and probably color as well -- was somehow linked to that property? Maybe that helps when debugging this.)
23Ava
Oct 10, 2026 5:14 PM UTC
Hello,
Emma Wingding
Oct 11, 2026 4:09 AM UTC
Hit this one myself, so here's a roundup of the workarounds that have helped me and others in this thread while we wait for a proper fix:
1. Swap the text property value first, then re-apply your text style from the style picker afterwards. Doing it in that order stops the swap from wiping the style out.
2. Set the text style on the main component's text layer itself rather than only overriding it on instances — swapped values inherit whatever is set on the main component.
3. If you use typography variables, binding the individual fields (font family, size, weight) directly to the text layer instead of using a text style seems to dodge the bug entirely — credit to Will Ballard for spotting that one.
4. For colour overrides, disconnecting the fill all the way down to the hex value on the variant helped in Charlesb's case.
Hope one of those unblocks you!
23Ava
Oct 12, 2026 5:20 AM UTC
Hello,
Emma Wingding
Oct 12, 2026 8:35 PM UTC
Hi 23Ava! It looks like your message may not have come through fully — all I can see is "Hello". If you're running into this text property bug, could you share a bit more about what you're seeing? The workaround that's helped most people here is swapping the text property value first and then re-applying the text style from the style picker afterwards. Happy to help you troubleshoot further once you've got more detail!
anniewarner
Oct 12, 2026 7:26 AM UTC
This sounds like a regression in the latest update. Ideally, the text content should stay linked across variants while each variant retains its own text styling. Have you tried separating the text style properties from the shared text property?
Hellen charless
Nrojb_Kramdnal
Nov 11, 2026 12:56 PM UTC
Same problem. Major bug. MAJOR.
