Basit Channa
Jul 4, 2026 7:44 PM UTC
Team locked over Starter limits - Move file and Trash actions silently fail
After downgrading from Professional to Starter, my team "Native Brains" ([redacted by moderator to remove personal information]) is locked for being over Starter limits: 137 Figma Design files across 3 projects (NB Projects, Design Systems & UI Kits, Portfolio), when Starter only allows 3 files in 1 project.
I understand the fix is to move or trash files to get under the limit. But every action I try silently fails:
1) Right-click > Move file... - the destination picker (Suggested/Starred/All tabs) never loads. Infinite spinner even after 10+ seconds. Tried on a single file and on 50 files selected at once, tried after a hard refresh, same result every time.
2) Drag a file onto Drafts in the sidebar - shows a confirmation "Do you want to move this file?", I click "Yes, move it", but after reloading the page the file is still in the original project and Drafts is unchanged.
3) Drag a file onto Trash - no confirmation even appears, and checking the Trash folder afterward shows nothing new was trashed.
I tested this repeatedly on multiple files, after full page reloads, and it is consistently a no-op. It looks like the locked state is blocking the exact actions that are supposed to unlock it.
Could someone help manually reorganize or unlock team [redacted by moderator to remove personal information] so it works on the Starter plan again? I'd rather not pay to temporarily reactivate Professional just to work around this. Happy to share screen recordings or more detail if useful.
adamsmasher
Jul 5, 2026 11:17 PM UTC
Hi, ​@Basit Channa! It looks like you’ve tried pretty thoroughly to reduce the number of files for the Starter team so you can edit.
Are you using the Desktop app or a web browser? If you’re using the app, can you try switching to the browser or vice versa? I want to rule out that it’s an issue with one or the other. It would also be helpful to have a screen recording if you continue have trouble - I can escalate this to our support team and include that with it. One other question: do you recall if you had any trouble moving files to drafts or other teams prior to downgrading? Thank you!
