Hugo-M
Jan 28, 2026 10:18 AM UTC
Swap component fixed height override
Hi,
I have a slot with a “swap” component, height and width set to hug.
When I swap this for, let’s say, my “Tag” component which have fixed height, I have a problem.
The height is correctly set to “Fixed”, but it match the previous height of the swap component.
If I go to hug, then fixed again, the tooltip show me the correct fixed height, but as soon as I click on it, it jumped to the value of the swap component.
Basically, that’s making it impossible to use with fixed height component.
The only way to use that would be to wrap my component into a new local component and apply it to the swap, but what a waste of energy !
Hugo-M
Hugo-MAuthor
Jan 28, 2026 10:19 AM UTC
because it’s impossible to manually set the fixed dimension of a nested instance, if this value is bugged the all component is good for garbage sadly 😥
