sunbun
Nov 6, 2026 6:30 AM UTC
Student Verification Failed Due to Last Name Mismatch Despite Official Enrollment Certificate
English
Hello,
I'm experiencing an issue while trying to verify my student status for Figma Education.
I submitted an official English Certificate of Enrollment issued by my university in South Korea. However, my verification was rejected with the following message:
"The last name shown in the document submitted did not match with what was provided on the verification form."
I don't understand why this mismatch occurred, as the document contains my official English name.
Could this be related to the Korean naming convention, where the family name is typically written before the given name?
Could you please clarify which part of my name was identified as mismatched and how I can resolve this issue?
Thank you for your assistance.
한국어 (Korean)
안녕하세요.
Figma Education 학생 인증을 진행하는 과정에서 문제가 발생하여 문의드립니다.
대한민국 소재 대학교에서 공식 발급한 영문 재학증명서를 제출했으나, 다음과 같은 사유로 인증이 거절되었습니다.
"제출한 서류에 표시된 성(Last name)이 인증 신청서에 입력한 성과 일치하지 않습니다."
제출한 재학증명서에는 공식 영문 성명이 정확하게 기재되어 있어, 어떤 부분에서 불일치가 발생한 것인지 이해하기 어렵습니다.
혹시 한국에서는 일반적으로 성(Family name)을 이름(Given name)보다 먼저 표기하는 관습이 있어, 이로 인해 인증 과정에서 문제가 발생한 것인지 궁금합니다.
구체적으로 성명의 어느 부분이 일치하지 않는다고 판단되었는지, 그리고 이 문제를 해결하여 학생 인증을 완료하려면 어떻게 해야 하는지 안내해 주시면 감사하겠습니다.
감사합니다.
Celine_Solution
Nov 6, 2026 11:10 AM UTC
Hey ​@sunbun , Celine from the Figma Community Support team here! The order of your family and given names could be relevant, but the rejection message alone doesn’t confirm the cause.
On the verification form, Last name means your family name or surname, and First name means your given name, regardless of their order on your certificate. Please check that the spelling matches your document, including spaces and hyphens.
Since SheerID handles student verification, please reply to the rejection email or contact directly figmasupport@sheerid.com. (Explain that your certificate was issued by a South Korean university and ask them to identify the mismatch, check whether the name order was interpreted correctly, and advise how to correct your existing application. You can also CC education@figma.com for visibility.)
Note: Please share your certificate and application details only through SheerID’s private support process, rather than in the Figma Forum as we cannot handle this here. Thank you!
Celine_Solution
