Stanislav Ran
Oct 1, 2026 1:09 PM UTC
Specific Figma file appears corrupted — layers/properties missing and file cannot be shared
I’m experiencing a serious issue that appears to affect only one specific Figma Design file.
The file still opens, but its internal state/UI appears to be broken.
Current symptoms:
  • Some elements/content disappeared.
  • The normal Layers/folder structure is missing or displayed incorrectly.
  • When selecting elements, some normal position/coordinate information and properties are unavailable.
  • Figma AI Agent no longer works correctly in this file.
  • Restarting Figma and restarting my Mac does not fix the issue.
  • Another member of my team opened the same original file and sees the same problems.
The most important diagnostic detail:
If I duplicate this exact file, the duplicated version works normally. The problem exists only in the original file.
The issue has now become even more serious: I can no longer share the affected original file with anyone. I’m unable to grant access to another person or to the Figma Support email address.
I already created an official Figma Support case: #2159948.
I initially submitted the wrong file URL in that ticket, but I later added the correct URL to the affected original file and explained the situation.
I also have a screen recording showing the problem and comparing the affected original file with the working duplicate.
Has anyone experienced a similar file-specific corruption or document-state issue?
If a Figma Support Specialist sees this post, I would also appreciate help reviewing or escalating support case #2159948.
I’m intentionally not posting the affected file URL publicly because it is a private work file. The correct URL has already been provided in the support case.
    ksn
    Oct 1, 2026 5:25 PM UTC
    Hi ​@Stanislav Ran - thank you for checking in with us here. We've been experiencing a higher volume of requests, and I apologize for the wait.
    Regarding the inability to share the affected file now, no worries (and we also understand your need to protect your work). Support can work with what you are able to provide.
    I did surface your ticket with our technical quality team for awareness, and I also made sure to highlight the file URL mixup.
    I can’t guarantee an exact timeframe of response, but rest assured that your inquiry has been received and will be reviewed as soon as possible. Thank you so much for your patience and understanding.
