hummh
Mar 25, 2025 1:27 PM UTC
Slots in components are treated as overrides and inherit styles to swapped components
Hello,
we have a huge issue with slots in our design system. From one day to the other, without any reason our slots in components are treated like they have been overridden (e.g. border color, bg color, ...). Those styles are then inherited to swapped components. You can be 100% sure that we didn’t customise the slots and all components have been tested extensively before, so why do they now have overrides? Where do the come from? What has changed in Figma?
The only solution is to go through all components in the system and reset the slots. Honestly Figma should save time not add additional work on our shoulders …
Hope you can help us to find out what is causing this issue in Figma and how we can prevent such things in the future.
Attached you find a file showing the problem.
Thx
Harald
    Sjur_Gronningsaeter
    Mar 31, 2025 10:40 AM UTC
    We have the same problem. When we swap to another component, the slot component styling is preserved, so we have to reset the fill and stroke manually.
    amexchuckles
    Jun 20, 2025 3:01 PM UTC
    We’re also experiencing this issue. Has anyone found out the cause?
    jisoo yoon
    Jun 27, 2025 2:07 AM UTC
    Same here. suffering from the same problem for weeks. Has anyone fixed this problem?
    Tyler Mitchell
    Jul 8, 2025 7:05 PM UTC
    It would be great to hear Figma’s take on this. We are experiencing it also. One thing I think works is using a rectangle vs a frame, but that would entail a huge lift on our end to make that change.
    Karl Anthoine
    Jul 10, 2025 1:28 PM UTC
    Same problem here. When a want to load a component in a slot, y lost a lot o styles (fill, border, ect...).
    I building a design system base on Slot, and i m in big trouble now …. because it’s not working fine
    It’s a major issue PLZ !!!!
