MiloW
Mar 11, 2026 12:23 PM UTC
Slots don't respect nested component's fill values?
Hi,
I don’t know if I’m the only one with this problem.
I have the slot. I configure it, etc. everything awesome.
I take the instance, try to use it.
Add an instance of the component that I had selected as the preferred one.
Now, it breaks my Fill for width and height for the component and the component doesn’t fill the slot area!
Now, I know it has to be changed to fill but weren’t slots supposed to be automatic? So that whatever is put there, it behaves like it should?
WTF?
Another BROKEN FEATURE… OMFG.
Celyn_L
Mar 13, 2026 8:44 AM UTC
Hi ​@MiloW, Celyn from Figma Community Support here.
Thanks for taking the time to share this feedback and call out the specific behavior you’re seeing with width and height not filling the slot area as expected.
I’ve shared this with the team so they’re aware of how this is affecting real workflows — this is helpful context for the team as they evaluate the current behavior.
Appreciate you raising this again.
MiloW
MiloWAuthor
Mar 13, 2026 8:47 AM UTC
Hello, yes, I know, I decided to write about it in two places, also for the people.
We’ll continue.
Ben64
Mar 13, 2026 3:08 PM UTC
Our team is maintaining our slot component work-around that existed before the native release for this reason.
Tip: Although annoying, we have found that a manual placement(drop the instance into the canvas next to your slot, drag and drop into slot) of the ‘slot content’ instance honors the auto layout defined at the main slot-content component - for whatever reason.
Straton_Roberts
Mar 16, 2026 6:25 PM UTC
We are also experiencing this issue. We have some components set to fill container within their component frame. When inserting those components into a slot, they add as a fixed width instead of filling the slot container like expected. This behavior adds an extra step that our designers need to do to properly use those components as they are coded.
However, if I drag an instance directly from the main component into the slot, then it respects the fill container and it works great. It doesn’t respect the fill when inserting from the “+” button on the slot or the quick insert menu.
Celyn_L
Mar 17, 2026 7:25 AM UTC
Hey ​@MiloW — I checked in with the team to get more clarity on the “Fill” behavior you’re seeing and wanted to share a quick update.
Could you help confirm if you are expecting the Fill settings to be inherited from the main component of the inserted instance, or from some configuration within the Slot itself?
For context, instances don’t inherit the Fill settings from their main components when inserted, and this same behavior extends to Slots as well.
​@Ben64 ​@Straton_Roberts — thanks for sharing your feedback here as well. I’ll be sure to pass this along to the team 🙌
MiloW
MiloWAuthor
Mar 17, 2026 11:15 AM UTC
​@Straton_Roberts has exactly the problem although I am not really able to drag and drop stuff as my component having the slot gets “crazy” - it doesn’t insert into the slot, it inserts the item wherever it wants…
IMO there should either be a switch for a slot “preserve added instances features” or something… or it should respect them just like that, IMO this is expected.
Ben64
Mar 17, 2026 5:53 PM UTC
Just also wanted to mention these as well - will create new posts if I can’t find anything related:
  • Cannot select a variant as a preferred instance. Kind of a drag as designers would only know there is a specific variant to be used by documenting it in written word. A preferred variant instance would clear up the communication without so much documentation.
  • Slots need something like an empty state that hides the slot by default if not filled instead of relying on booleans to hide them
Leigh Henson
Mar 24, 2026 2:13 PM UTC
I am also seeing this issue on my team. I am an authoring designer working on components, and the Slots feature is not honoring Fill on components when they are set as Preferred Instances for the Slot. It is fine if we drag and drop them in, but not if they are selected from the preferred list.
As another user pointed out, we also cannot add the component variants as Preferred Instances in the Slot; each must be a single component. That would be fine if we could then select the variants from each instance, but that option is not available currently.
I was experimenting with breaking a component’s variants out into multiple variants but I would rather not do that when the component has and needs shared properties. I think for several applications I wanted to use with Slots we’ll have to wait until Fill is fixed and perhaps the ability to select variants.
RobWinter
Apr 6, 2026 5:35 AM UTC
Native slots seem generally a very good idea. I’m having the same issue with the width prop though.
I’ve set main component sets to have fixed width & auto layout, then all variants inside have width set to fill. My slot layer has auto layout set on it, and I expect the instances I place inside it to bring their width prop of fill with them. Having to set each new instance to fill the width definitely feels like an extra step.
My existing custom slot system relied on instance swapping, where the instance I’m swapping from has width set to fill, and there I see the correct width behaviour, I don’t have to set it to fill each time, it just works. Probably because there’s an instance already there which holds that prop. But I do think the new native slots should have this little upgrade.
I’m keen to hear of cases where this wouldn’t be desirable though… 🧐
Celyn_L
Apr 7, 2026 9:56 AM UTC
Thanks everyone for flagging this and for sharing your experiences — this context is really helpful.
Slots is still evolving, and the team has heard your feedback here and is continuing to review ways to improve the experience.
To clarify a few points raised in the thread:
  • When inserting components into Slots, the “Fill” setting may not carry over automatically and may require manual adjustment. This is due to how auto layout frames handle inserted components and is expected behavior. The behavior is consistent between Slots and standard frames.
  • For binding component properties within slots (e.g. controlling variants or values) — we’d recommend using variables/modes if you’re trying to achieve this.
  • The ability to set specific variants as preferred values is something we’re exploring.
We understand the expectation for inserted components to behave more predictably without requiring manual adjustments, and this is valuable feedback as we continue shaping the feature 🙌
