AntonioB
Apr 7, 2026 12:38 PM UTC
Slot item override in nested instance breaks full slot propagation across all items
In a component with a slot containing multiple items, changes to the items stop propagating in the instance once any individual item within that instance has been manually overridden.
Consider a menu component containing a slot with menu-item components. At some point, I use that menu component by instantiating it inside another component — say, a menu-app — which then appears across multiple views. I want any changes made to the menu-items to propagate to all those instances, keeping every view consistent. And this works as expected, until I make any change to any of the menu-items within the instance. I could understand that manually overriding a specific item in a slot prevents changes from propagating to that same item — I could live with that. But the problem goes further: changing anything on any item — such as its position in the stack (which is critical if I ever decide to reorder the menu items) — completely breaks propagation of any slot-level changes across the board.
Kerry_Johnson
Jul 17, 2026 4:23 PM UTC
This is like handing you a machine guns worth of potential and power but only giving you a 2 bullets to play with.  What.  Also, it completely goes against the philosophy of components/slots, so this must be proof of some nasty Figma architectural code issue or spreading their staff so thin that instead of course correcting to stay true to the component philosophy they just tore the rest of the connect the dots page and threw it in the trash.
