flav
Mar 13, 2026 3:58 PM UTC
Slot description is not clickable
Hi all 😀
Our team has been tickering with the new Slots feature, and we love it a lot.
We really try to keep everything detailed whenever we can, and we were overjoyed to see that each Slot property can get their own individual description on “How to use this slot”, just like the Components do. However, while the components description preview is truncated if it is too lenghty but clickable to display the whole text, the Slots description isn’t clickable, and there’s no way to read the whole documentation.
Is this an oversight or is this the intended behavior?
jjortanez
Mar 19, 2026 9:35 PM UTC
I have the same issue - commenting to track in case someone finds a solution ! Thanks
jjortanez
Mar 19, 2026 9:40 PM UTC
I see that a few others have posted a similar issue - the slots description is limited to 2 lines and links are not appearing in the feature. For components, users are able to click this description area of the right panel and a popup appears with more text and links. I expect slots to do the same.
Please let me know if you’ve solved for this - thanks!
Mar 20, 2026 5:42 AM UTC
Hi there,
Thanks for flagging this!
I tested and can reproduce the issue: when you select a slot with a description, the right sidebar only shows two lines and any links in the description aren’t clickable.
I found a related internal report and have added this forum post to it for review to increase visibility.
Our engineering team is aware of the bug and is working on a fix. We’ll keep you posted here as we have updates.
Thanks!
