Vitalii_Sologub
Apr 20, 2026 2:57 PM UTC
Slot content's layout breaks in prototypes
I use a Slot in my Component with default content inside. The content and the whole layout are set to Fill container, and it works as expected in mockups, but in prototypes the Slot’s content is displayed with default dimensions:
Celyn_L
Celyn_LSolution
May 14, 2026 5:49 AM UTC
Hi ​@Vitalii_Sologub, thanks so much for your patience here.
We’ve now rolled out a fix, and this issue should be resolved.
Could you please try the following steps to see if it resolves things on your end?
  • Reload your tab or Figma client
  • For any problematic slots, try regenerating the affected instances or clicking into them to refresh
These should update the instances and help apply the fix.
If you’re still seeing the issue after trying this, feel free to share a quick screen recording and we can take a closer look 🙌
Celyn_L
Apr 23, 2026 2:21 AM UTC
Hi ​@Vitalii_Sologub, Celyn from Figma Community Support here.
Thanks for sharing the screenshot and details.
From what you’ve described, it looks like the content renders correctly on the canvas (396) but falls back to its default dimensions (328) in prototype mode.
To help narrow this down, could you share a bit more about your setup?
  • Is the Slot content coming from a nested component or variant?
  • Does the same behavior happen with simpler content (for example, a basic frame set to Fill)?
  • Are you seeing this across different files, or just this one?
As a quick check in the meantime, you could also try:
  • Duplicating the file to Drafts and testing there
  • Replacing the Slot content with a fresh layer set to Fill
  • Testing in both the Desktop app and browser
If you’re able to share a file link here and invite support-share@figma.com with “Can View” access, it will help us reproduce and investigate this more effectively (Note: this won't impact your billing).
Thanks!
Vitalii_Sologub
Apr 23, 2026 12:13 PM UTC
Hi ​@Celyn_L,
The structure is the next:
  1. Widget template component containing a slot;
  2. Instance of the Widget template component wrapped into a Widget badges and Widget to-dos components with overrides and content placed into their slots.
I’ve recreated the setup from scratch in the new file and tested 3 scenarios in both Chrome browser and Mac Desktop app:
  1. Component instance placed into the slot in the component instance (template) nested in another component;
  2. Non-component elements placed into the slot in the component instance (template) nested in another component;
  3. Non-component element placed into the slot in the component instance (template).
Only the third scenario works as expected, the first two fail to render properly in the prototype:
Please see the file.
Celyn_L
Apr 24, 2026 3:08 AM UTC
Thanks for taking the time to recreate this setup and breaking down the three scenarios so clearly - that’s really helpful​ ​@Vitalii_Sologub 🙏
From what you’ve shared, it looks like the issue shows up specifically when a Slot is used inside a component instance that’s nested within another component, and:
  • Placing a component instance into the Slot doesn’t render correctly in prototype
  • Placing a non-component element into that same nested setup also doesn’t render correctly
  • But placing a non-component element into the Slot without that additional nesting layer works as expected
It’s also helpful to know you’re seeing this consistently across both Chrome and the macOS desktop app.
I’ll share your file and these exact scenarios with the team so they can take a closer look at what’s happening here.
If you notice any other patterns (for example, specific layer types or certain nesting depth that consistently breaks), feel free to share those too.
Really appreciate you putting together such a clear repro, I’ll follow up here as soon as I have any updates.
Celyn_L
Celyn_LSolution
Vitalii_Sologub
May 14, 2026 12:09 PM UTC
Hi ​@Celyn_L!
Thank you for the update and for notifying! Now it seems to work correctly. I briefly tested this with new components, and continue with more configurations.
