Erik_Goens1
Feb 27, 2025 12:02 AM UTC
Slides templates are empty
After creating a template with 24 slides, I’m unable to see the contents of the slides after clicking the “View template” option or when adding a new slide in a new presentation. Occasionally the contents of the last three slides might appear, but that reset remain empty. The template has been shared with the team.
I can hit the “Add all slides” option and each slide presentation shows up (see left column below) but the “preview” is not working at the moment.
Feb 27, 2025 5:58 AM UTC
Hi Erik,
Thanks for reaching out. I'm checking with our internal team. I will get back to you when I have anything I can share with you.
Thanks for your patience.
Toku
Erik_Goens1
Mar 10, 2025 4:24 PM UTC
​@y_toku following up on this to see if your team has made any movement on this issue?
Deanna_P
Mar 10, 2025 6:57 PM UTC
Came here with the same issue. It has been happening for a few weeks now and on a file the entire org uses.
Mar 11, 2025 12:48 AM UTC
Hi ​@Erik_Goens1 ​@Deanna_P
Sorry for the delayed update! Our engineering team just released a fix but we have to need you re-publish the template to fix the issue. Could you try republishing to see if it’s back to normal?
If the issue isn’t fixed, you might have to ensure that all the slides have updates (e.g. you can change all of the backgrounds to a different color and then undo, in order to do this).
Please let us know if the issue persists.
Thanks for the patience!
Toku
Erik_Goens1
Mar 11, 2025 3:04 PM UTC
Thanks for the quick reply ​@y_toku . I was able to resolve the issue yesterday by republishing my template. I did unpublished it first before pushing a change.
Mar 12, 2025 2:07 AM UTC
Thanks for confirming ​@Erik_Goens1 ! Glad to know it was resolved. Please let us know if you have any issues again. - Toku
