Subhankar Sarkar
Apr 3, 2025 9:01 AM UTC
shift+command+r are not working
There is no paste and replace option on the menu after I copy the object and when I use command+shift+R, it turns into rename action. Is there anyone know how to fix it?
    Apr 10, 2025 7:44 AM UTC
    Hi ​@Subhankar Sarkar
    Thanks for reaching out. Could you try reloading your tabs and restarting Figma to see if that resolves the issue? I've tested it on my end, and everything appears to be working normally in both the browser and the desktop app.
    If the issue persists, could you please share some screenshots or a screen recording so I can try to reproduce the problem?
    Thanks!
    Toku
    Ponomarev Denis
    Jul 15, 2025 7:01 AM UTC
    Cmd + Shift + Alt + V
    Andrei Cercel
    Sep 29, 2025 12:08 PM UTC
    It happened to me as well. Can be related to upgrading to Tahoe 26 (Mac OS)?
    I’m on M4Pro
    The Denis command worked, but…. too many fingers to use :)))
    Andrei Cercel
    Sep 29, 2025 12:29 PM UTC
    I’m on M4Pro
    I think I found the issue, at least on my side.
    I check all the things, I added a new shortcut for in the Settings/ Keyboard on my Mac. But I discovered that I have an app running in background (Be Focused) and when I pressed shift+cm+r the timer was activated :)))
    Now it is working well, thank you
