Veniamin_Mylnikov
Jul 15, 2026 12:47 PM UTC
SF Pro Letter Spacing Issue
We are experiencing the same issue with SF Pro.
In our case, SF Pro is uploaded to our Figma Organization Fonts, so everyone should be using the same cloud-hosted font files. This means that a mismatch between different locally installed font versions is unlikely to be the cause.
The letter spacing becomes visually tighter than expected, even though the font, font weight, text style, and letter-spacing values remain unchanged. The text can appear different after selecting the layer or entering text-edit mode.
We experienced essentially the same issue a couple of years ago. It was later fixed, but it appears to have returned during the past two weeks.
We have not changed our typography setup, text styles, font files, or the way the font is distributed for several years. The issue started appearing again without any changes on our side, so this looks like a regression in Figma’s text rendering or layout caching rather than a problem with the font itself.
Could the Figma team investigate this separately from the local font version mismatch? We can provide a reproduction file or screen recording if needed.
    ksn
    Jul 15, 2026 5:34 PM UTC
    Hey ​@Veniamin_Mylnikov - thank you for reporting. I saw you had actually posted this in a similar post over here, but I split it into a new topic here so we can address you directly.
    I can file a bug report / check in with our support team to see if there are any known issues. If you could grab a screen recording *and* provide a copy of the file you’re reproducing it in, that would be phenomenal. I’ll make sure to share it. for review.
    For the file, we only need view-only access to the one you’re able to share. Please share that access with support-share@figma.com.
    For the recording, you should be able to upload and share it as a response. If you’d prefer to not share that publicly, please feel free to PM me and I can work with you there.
    Thank you!
    Veniamin_Mylnikov
    Jul 16, 2026 5:35 AM UTC
    ​@ksn hello!
    invite sent
    link to file
    ksn
    Jul 16, 2026 8:29 PM UTC
    ​@Veniamin_Mylnikov Thank you! I just created an escalated support ticket on your behalf to have this looked at. There seems like there is some kind of local conflict at play, and I want to be sure it’s looked at carefully. The number is #2019838.
    Appreciate your patience!
    rachelemily
    Jul 19, 2026 10:13 PM UTC
    Hi, we’ve been having the exact same issue with the SF Pro font. Same behaviour as shown in the video attached above.
    adamsmasher
    Jul 19, 2026 10:45 PM UTC
    Thanks for your reply, ​@rachelemily - stepping in for ​@ksn. It looks like our engineers released a fix for this a few days ago. I’m not sure if you’ve done this yet, but can you quiet Figma entirely and re-open the file? If you still see the same issue, try clearing your browser cache and reloading. Let me know if neither action resolves the issue for you, and I’ll help create a ticket for you with our Technical Quality team.
    rachelemily
    Jul 22, 2026 12:16 AM UTC
    Thank you ​@adamsmasher - it looks like it’s been resolved on my end too after quitting and re-opening Figma. Thanks!
