yoyoboy_figy
Dec 8, 2025 2:35 AM UTC
Severe 20–30s Lag When Using Cut/Paste on MacBook Pro (M1)
I’m using a MacBook Pro (M1), and for the last two days I’ve been experiencing a severe delay when cutting or pasting objects in Figma. Each action takes around 20–30 seconds to apply. This makes it very difficult to work and breaks my workflow.
This issue is specific to Figma — other apps respond normally.
Please help diagnose what might be causing the slowdown and how to fix it.
Junko3Solution
Dec 9, 2025 7:02 AM UTC
Hi there,
We released a fix that should help with this issue. Could you try giving Figma a full refresh and see if things are working again?
Sorry for the disruption this issue caused to your workflow, and thanks so much for flagging!
Dec 8, 2025 2:22 PM UTC
Hey ​@yoyoboy_figy , Celine from Figma here. Thanks for reaching out, and I’m sorry for the slowdown you’re experiencing!
To investigate this properly, our Technical Quality team will need more detailed information. Since we can’t collect account-specific data here in the Forum, I’ve gone ahead and create a support ticket on your behalf so we can gather the details needed for investigation.
For reference your case number is 1631840 , please check directly your inbox (via your email address linked directly with your Figma account: pxxxxn@sxxxxai). Thank you!
llamar
Dec 8, 2025 3:42 PM UTC
I am also experiencing the same issue and I am also working on a Mac. When I cut or delete multiple frames at once, it’s causing a 20-30 second lag. This issue started for me on 12/4/25 and it has been happening on the app and desktop version. I have tried clearing my figma cache, restarting the app and removing some files to increase memory storage and nothing has worked. In addition, it seems to happen in some files and not others.
Dec 8, 2025 3:55 PM UTC
Hey ​@llamar , sorry for the disruption into your work and for flagging this! I’ve also gone ahead and created a support ticket on your behalf so our Technical Quality team can take a closer look at your case. For reference, your case number is 1631981 (please check your inbox via your email address:  lxxxxr@nxxxx.oxg). The team is waiting for some additional details from you so we can investigate it further. Thank you!
Thyago Furtado
Dec 9, 2025 12:06 AM UTC
Hello, ​@Celine_ I also posted about lag and freezing issues, starting last week, likely due to the new update. No replies on that topic. Please update me on a solution once one is available. Thank you
Junko3Solution
Hi there,
yoyoboy_figy
Dec 9, 2025 7:14 AM UTC
Hello ​@Junko3 Its working fine on my Macbook pro m1.
Thanks for saving me.
yoyoboy_figy
Dec 9, 2025 10:38 AM UTC
Its woking fine for me. Can you pelase check again? ​@llamar
