Antonius Indrawan Prabowo
Dec 3, 2025 1:48 AM UTC
Search in variable table is not working
I use variables mainly to store string values related to copies that I wrote in my app
Today I found that the search function is not working, whenever I tried to search for something it does nothing. The issue persist across files.
is there anything I can do to fix this issue?
Junko3Solution
Dec 4, 2025 2:02 AM UTC
Hi there,
Some of you may have already noticed, but our engineers just pushed a fix for this. Searches and filters in the variable modal should be working now.
Please refresh Figma and see if it’s working on your end.
Thanks again for the report and for your patience while our engineers worked on this.
Dec 3, 2025 5:31 AM UTC
Hi ​@Antonius Indrawan Prabowo,
Thanks for flagging this! I understand you’re running into an issue with the search bar in the Variables modal.
I tested this on my side and I’m also seeing that searching for a variable name or filtering isn’t working as expected, both in Chrome and in the Figma Desktop app.
I’ll pass this along internally so our team can investigate. Once I hear more, I’ll follow up here with an update.
Thanks again for letting us know!
Anna_Bromek
Dec 3, 2025 1:33 PM UTC
I have the same problem - variable search and filters don’t work.
It was working all right this morning, but then I received a Figma update - with the new variables modal layout, and with search field problem... Additionally, there is something that looks like an empty context menu container, for a collection that also magically appeared with the update:
I did almost the same tests as ​@Viorel Brinzanescu, with the same result. I reported a bug, but since it went through AI/Figma bot and I haven’t received a standard email confirmation this time, I’m not confident it actually reached Support...😟
Viorel Brinzanescu
Dec 3, 2025 1:36 PM UTC
Hi! I’m also experiencing the exact same issue with the Variables panel.
The search bar doesn’t return any results at all, and this happens across all files, including completely blank ones.
I’ve already tried:
  • restarting Figma (desktop + web)
  • clearing cache
  • logging out and back in
  • disabling all libraries
  • testing in multiple browsers
  • creating new files
  • restarting my computer
The issue still persists and the search field does nothing.
Do you have any updates on a fix or any known workaround?
Thanks! 🙏
Sean_Finnegan
Dec 3, 2025 2:10 PM UTC
same as above.
keengood
Dec 3, 2025 8:56 PM UTC
Hey! Same issue here and following this thread
Dec 4, 2025 12:29 AM UTC
It is now working as intended thank you!
Now I can do copy audit in peace 😁
Junko3Solution
Hi there,
Anna_Bromek
Dec 4, 2025 7:23 AM UTC
Yup, it’s fixed! Thank you Figma for a quick response 😊 🙌🏻
