Griff L'Ecuyer
Jul 29, 2026 10:06 PM UTC
Scaling and Corner Radii are now anchored towards the absolute top left, not shape's relative top left.
When resizing a rectangle or ellipse, or any sort of shape object, dimensions are tethered to the relative top-left corner of the shape—meaning that any increasing or decreasing of the width and height would happen relative to the shape’s top-left corner. This is helpful, since I can rotate an object 180°, and that resizing anchor would move with it, allowing me to adjust dimensions from the bottom right corner.
However, recently the shortcut associated with adjusting those dimensions (Cmd + Directional Arrows) now ignores this rule, making it so that resizing any shape with these shortcuts is always resized relative to the absolute top left corner, no matter the shape’s rotation. This requires me to make those adjustments solely using the Width and Height fields, which is pretty tedious.
Similarly, corner radii are also now anchored to the absolute top-left. But when multiple objects of different rotations are selected, then it uses the relative top-left corner. So I have to use a workaround by duplicating the object, selecting both, and then adjusting the corner radii.
I’m an icon designer, and I need predictable ways to edit rotated objects from any direction. These recent changes to the way dimensions and corner radii of shapes are edited is incredibly disruptive to my workflow, and makes my design process 10 times harder.
Griff L'Ecuyer
Jul 29, 2026 10:50 PM UTC
Here are videos that demonstrate what I’m talking about:
adamsmasher
Jul 31, 2026 6:25 PM UTC
Hi, ​@Griff L'Ecuyer! I can appreciate how the differences in origin are making it more difficult for you to intuitively make changes. Thanks for including the screen recordings - they make it much easier to see what you’re describing.
Out of curiosity, what is the preferred behavior for you here? I’m checking with our team to see what is expected, but I’d like to know what you think as well. Thanks!
Griff L'Ecuyer
Aug 3, 2026 10:51 PM UTC
​@adamsmasher Thanks for your reply! My preferred behavior is that the shortcuts for adjusting the size—i.e. Cmd + Up/Down/Left/Right— all follow the pattern of how shapes scale using the width and height panel. The shortcut should scale those shapes relative to the rotation of the shape.
Griff L'Ecuyer
Aug 3, 2026 10:58 PM UTC
While we’re on the topic, I think a better solution here is more customization on what that point of origin is. Right now, Figma only provides 1 point of origin—the top left corner of an object—whether it’s the absolute top-left using the shortcuts, or relative top-left when using the W/H panel. But either method still requires workarounds to precisely scale from any other point of origin.
In Adobe Illustrator, there is a tool called the Reference Point in their Transform panel that allows you to adjust that point of origin for all transformations, including rotation and scaling (labeled “I” in the image below). That feature applied to objects in Figma would be exceptionally useful for more predictable object scaling and rotation. In Illustrator, the default point of origin is from the center, not top-left like Figma.
Figma has a tool that looks similar, called “Constraints”, which defines how objects are transformed when the parent frame is scaled. But the actual function of that tool is very different than setting a point of origin for object transformations.
James Vince
Aug 4, 2026 6:07 AM UTC
I’ve noticed similar behavior and I agree that consistency is really important when working with rotated objects. Figma’s strength has always been its predictable editing workflow, especially for detailed design work like icon creation.
Having resize shortcuts and corner radius adjustments behave differently from the regular transform logic can definitely slow down precision workflows. Hopefully Figma can bring back a more consistent object-relative approach or provide a setting to choose between absolute and relative anchors.
adamsmasher
Aug 8, 2026 6:39 PM UTC
Thanks for the suggestion, ​@Griff L'Ecuyer, and thanks for your post as well, ​@James Vince. I’ve shared the feature suggestion in the discussion around your feedback. If I hear anything else I can share I’ll post again to let you know!
