Djalma Gabriel
Sep 4, 2026 1:14 PM UTC
SAML SSO – Erro de certificado de assinatura no Figma com Microsoft Entra ID
Hello Figma Support Team,
We need assistance with a SAML SSO configuration for one of our Figma Enterprise organizations. Our customer currently has two independent Figma Enterprise contracts/organizations. SAML SSO and SCIM are already configured and working correctly in the first organization. We recently configured SAML SSO and SCIM for the second Enterprise organization.
For this second environment, we created a separate Enterprise Application in Microsoft Entra ID and configured it using the Tenant ID, Entity ID and ACS URL provided by Figma. However, when an existing Figma user attempts to authenticate by selecting "Use single sign-on (SSO)", the authentication fails with the following error: "The certificate configured in Figma does not match the IdP's signing certificate." Error details: HTTP Status: 422 Error ID: auth.error.saml_invalid_signature Message: The certificate configured in Figma does not match the IdP's signing certificate.
The first Figma Enterprise organization continues to work normally with SAML SSO using its own Microsoft Entra ID application. We would like Figma Support to help us investigate the configuration of the second organization and confirm whether there is any limitation or conflict when configuring two independent Figma Enterprise organizations using separate Microsoft Entra ID Enterprise Applications.
Could you please help us with the following questions?
1. Is it fully supported to configure SAML SSO and SCIM for two independent Figma Enterprise organizations using separate Microsoft Entra ID Enterprise Applications?
2. Is there any known limitation or restriction when the same Microsoft Entra ID tenant is used for multiple Figma Enterprise organizations?
3. Could the SAML signing certificate used by the first Figma application affect or conflict with the second Figma organization?
4. Does each Figma organization/tenant require a different SAML signing certificate, or can the same Microsoft Entra ID signing certificate be used for multiple Figma applications?
5. Could you please verify whether the SAML configuration associated with the second Figma Tenant ID is correctly associated with the expected IdP signing certificate?
6. Is there any specific configuration that we should review in Microsoft Entra ID regarding the SAML Signing Certificate, Entity ID, Reply URL (ACS), Sign-on URL, or federation metadata?
We can provide the following information if required: - Figma Tenant ID - Microsoft Entra Enterprise Application configuration - SAML metadata - SAML signing certificate details - SAML authentication/error logs - Screenshots of the configuration and error We have attached a screenshot showing the error encountered during authentication. Thank you for your assistance.
Sep 4, 2026 4:19 PM UTC
HI ​@Djalma Gabriel, thanks for reaching out!
I understand how this must be slowing down your workflow. Good news for your first questions: running two independent Figma Enterprise orgs from the same Microsoft Entra ID tenant is fully supported, and each org should have its own Entra Enterprise Application. There's no limitation or cross-org conflict there, and the certificate on App 1 has no bearing on Org 2. Each Entra Enterprise App generates its own SAML signing certificate, so the cert uploaded to Org 2 must be the one from App 2; they don't need to match, and they shouldn't. auth.error.saml_invalid_signature almost always means the cert stored in Figma for that org isn't the one currently signing assertions from that app.
A few things worth checking in Org 2:
  • Cert source and format: In Entra, under SAML Signing Certificate, download Certificate (Base64) from App 2 (not the Federation Metadata XML, and not a copy of App 1's cert). If the cert was ever reassembled or edited by hand in a text editor, re-download a clean copy — stray line breaks or missing header/footer lines will fail validation.
  • Active vs. inactive cert: If Entra has more than one certificate listed, confirm the one you uploaded is the Active one. Entra sometimes creates a new cert during setup.
  • Force the update in Figma: Figma won't always pick up a rotated cert on its own. Go to Admin → Settings → Log in and provisioning → SAML SSO → Edit configuration, select "Other" as the identity provider, re-enter the IdP Entity ID and IdP SSO Target URL from App 2, and re-upload the Base64 cert. Full steps here: Set up a custom SAML configuration.
  • Cross-check the basics against Org 2's own values: The Identifier (Entity ID), Reply URL (ACS) and Sign-on URL in App 2 must match what Org 2's SAML SSO page shows (not Org 1's), and NameID format should be urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress. Guide to SAML SSO
  • Keep a fallback while testing: Leave the org's authentication set to allow email/password so an admin can always get back in if a config change goes sideways, then test SSO in an incognito window. Set login and authentication method
On your question 5, verifying the stored certificate against your specific Tenant ID: that needs account-level access, so we can't do it here in the public forum, and please don't post Tenant IDs, metadata, or cert details in this thread. Could you open a support request as an Org Admin of the second org? Attach the Tenant ID, App 2's SAML metadata, and the Base64 cert, and link back to this thread; our Enterprise team can compare the stored cert against your assertion directly.
One question that'll help either way: is the error hitting every user in Org 2, or just some? If it's org-wide it points squarely at the cert/config; if it's isolated to a few people it's usually an app assignment or duplicate-account issue instead.
Please note these are general best-practice guidelines; depending on your IdP configuration additional steps may be required, and Figma can't guarantee they'll work for every setup. IdP implementation is undertaken at the customer's own risk. But let us know how it goes, I can also help connect you with our support team, as needed.
