esra çakın
Aug 23, 2026 10:34 AM UTC
Right-click stopped working on figma canvas on ipad
Hi Figma team,
Right-click suddenly stopped working on the Figma Design canvas on my iPad. It was working normally until yesterday.
The important detail is that right-click still works everywhere else in Figma, including the Layers panel and Figma menus. It only does not work directly on the Design canvas.
I am using an iPad with a mouse.
I have already tried:
  • Refreshing Figma multiple times
  • Completely restarting the iPad
  • Creating and testing with a new Figma account
  • Opening the file in Safari
  • Opening the file in the Figma app
  • Checking that “Ctrl + click opens right click menus” is enabled
  • Disabling “Show Agents on canvas”
  • Trying Ctrl + left-click
  • Trying Command + right-click
  • Trying a long right-click
None of these solved the problem.
Right-click works in the Layers panel, but not on the canvas. This makes normal workflows such as grouping layers, changing layer order, renaming, and other context-menu actions very difficult because I normally use the right-click menu for these operations.
This started suddenly today, although it was working normally yesterday.
Could you please check whether this is a current Figma/iPad canvas bug?
I can provide screenshots or a screen recording if needed.
Thank you.
Tom Reem
Tom ReemSolution
Aug 26, 2026 8:11 PM UTC
Thanks, both! The extra detail and the recording gives us more clarity. 🙏🏻
Quick summary on where we’re at: Between the two of you, I’m noting this is happening on across two iPad models and two iPadOS versions, on both the Figma Design and FigJam canvases, with Apple and third-party pointing devices, in new files and on new accounts.
I've raised this to our Technical Quality team for a closer look. I've also emailed each of you with instructions for sharing file access securely, which will help us take a deeper dive:
  • ​@esra çakın → 2095127
  • ​@connell.byrne → 2095121
Please check your inbox for a message from me and keep an eye on your spam folder too in case anything gets filtered there.
We’re looking out for related reports and will update the thread as we hear more. Keep us posted on how it’s going.
Tom Reem
Aug 23, 2026 5:11 PM UTC
Hey ​@esra çakın, welcome to Figma Forum and thanks for testing this so thoroughly before posting. The screenshots help a lot: I can see Ctrl+click opens right click menus is enabled on your end, so we can rule that out.
The fact that right-click still works in the Layers panel but not on the canvas is useful as well. I wasn't able to reproduce it on my end, so a few more details would help me narrow it down and get it in front of the right team:
  1. Which iPad model and OS version are you on?
  2. What type of mouse are you using with your iPad and how is it connected?
  3. You mentioned testing with a new account — is this happening in every file you open?
  4. Does right-click work on a FigJam canvas on that same iPad? Different editor, so it helps me understand whether this is specific to Figma Design or broader.
  5. If you have access to a Mac or PC, does right-click behave normally on the canvas there?
Once I have those I'll take this to the team for a deeper dive. Thanks again for the detail so far. 🙏🏻
connell.byrne
Aug 24, 2026 10:10 AM UTC
I have the exact same issue.
  1. iPad M5 Pro (11 Inch)
  2. Issue present with Magic Keyboard trackpad and Magic Mouse
  3. Every file, its a canvas bug
  4. Issue present on FigJam
  5. MacOS Chrome - same account - works fine.
Tom Reem
Aug 25, 2026 7:23 PM UTC
Thanks for weighing in and confirming, ​@connell.byrne — that's a really useful breakdown, especially FigJam being affected too with the same account working fine in Chrome on macOS. We've had a couple of other reports come in along these lines, and the team is investigating.
​@esra çakın and ​@connell.byrne, could I ask for a few more things from you both?
  1. Your iPadOS version (Settings → General → About)
  2. Does a two-finger tap directly on the touchscreen open the context menu on the canvas, or does that fail as well?
  3. A screen recording of the issue — if you can capture the Layers panel working and the canvas not working in the same clip, that contrast is really helpful
With that, I can escalate your specific reports for further review. If you'd rather share the recording privately, you can do so via the Support Hub — type in "report a bug" and attach the file there. Let me know if you have any trouble getting in touch.
connell.byrne
Aug 26, 2026 6:47 AM UTC
Hi
iPadOS 26.6
Two fingers works as normal - only connnected pointing devices that don’t work
Hope this helps
Connell
esra çakın
Aug 26, 2026 8:25 AM UTC
Hi Tom, thanks for getting back to me and for looking into this.
Here are the additional details:
  1. iPad model: iPad Pro 13-inch (M4)
    iPadOS: 26.5.2
  2. Mouse: Piranha mouse. I also tested with a different mouse, and the exact same issue occurs, so it doesn’t appear to be mouse-specific.
  3. Yes, the issue happens with newly created files and also with a newly created Figma account.
  4. I tested right-click on a FigJam canvas on the same iPad, and it also does not work there.
So right-click works in the Layers panel and in other Figma menus, but it does not work on either a Figma Design canvas or a FigJam canvas.
The issue started suddenly. It was working normally before.
I hope these details help narrow it down. I’m happy to provide a screen recording or any other information you need.
Thanks
esra çakın
Aug 26, 2026 8:38 AM UTC
Hi Tom,
I’ve attached a screen recording showing the issue.
As you requested, the recording shows that right-click works normally in the Layers panel, but right-click does not open the context menu on the canvas.
I also tested two-finger tap on the canvas, but that does not open the context menu either.
My iPadOS version is 26.5.2.
Hopefully the recording helps the team identify the issue. Thank you for investigating this!
Tom Reem
Tom ReemSolution
Tom Reem
Nov 15, 2026 5:06 PM UTC
Quick update: Our Engineering team has your reports, and I’ve checked in with them for an update. We’re continuing to monitor this and will share more here when we have news.
