Ana Faustino
Apr 14, 2026 10:29 AM UTC
"Review updates" window not resizing and other bugs
I can’t resize the window, either by dragging the sides, the corners, or double-clicking on the top bar. Additionally, clicking to move inside the window now moves the window, instead of the component. To move around the frame, I need to use the middle-button on the mouse.
There is also a bug where clicking another component on the “Updates” list opens another window. Clicking the “close” button on one window closes all the windows, including the “Manage libraries” window.
    AskDave
    Apr 14, 2026 10:56 AM UTC
    Hi Ana,
    Dave here from Figma’s community support team 😊
    Thanks for flagging this, that does sound pretty frustrating, especially with multiple things breaking at once. What you’re describing (window not resizing, dragging behaviour changing, multiple windows opening, and closing one closing everything) definitely isn’t expected behaviour.
    A couple of quick things you can try first:
    • Refresh the file or your browser/app
    • Duplicate the file and check if the issue still happens there
    If it continues after that, it’s best to report this as a bug so the team can look into your specific setup. When you do, it really helps to include:
    • A link to the affected file
    • A short screen recording showing the behaviour
    • Steps to reproduce (if you can consistently trigger it)
     Bug report directly to Figma Support: Figma Learn - Help Center
    You can also check out some general troubleshooting steps here:
    https://help.figma.com/hc/en-us/articles/31304610458647-Troubleshoot-in-Figma-Make
    Really appreciate you calling this out, issues like this are important for the team to investigate properly.
    Ana Faustino
    Apr 14, 2026 11:42 AM UTC
    I’m using the app, and this issue has been happening for a while; I assumed it needed an update, but I updated Figma today and it wasn’t fixed. Restarting the app and refreshing the file did not help - this issue happens in all files, and while using the browser too.
    I’ll open a bug report. Thanks.
    Ana Faustino
    Apr 14, 2026 11:56 AM UTC
    Hi ​@AskDave, what’s the fallback for the bug report system not working? This is getting a bit ridiculous.
    Apr 14, 2026 2:16 PM UTC
    Hey ​@Ana Faustino , Celine from the Community Support team, I am working closely with ​@AskDave , happy to help!
    Sorry for the trouble with the Support Hub, and thanks for trying those steps. I've checked internally and can confirm that your request has been successfully received by our support team. Your case number is #1848721 for reference, and I've added a follow-up note to increase visibility.
    Someone will be in touch with you soon, thanks for your patience! 🙏
    Update: I can see in the backend that your case  has been forwarded to our Technical Quality team for further investigation. Please feel free to add any additional information directly in your case, thank you!
