FleetUI
Jun 11, 2026 5:46 PM UTC
REST API: GET /v1/images/:key returns 400 "must provide either user_id or plan_key" when using a plan access token with the version parameter
Hi,
  We recently migrated our integration from a personal access token (figd_...) to a plan access token (figp_...), and the image render endpoint started failing — but only when the version query parameter is included.
  Request:
  GET https://api.figma.com/v1/images/:file_key?ids=9544:3051&format=svg&scale=1&version=<version_id>
  X-FIGMA-TOKEN: figp_...
  Response:
    "status": 400,
    "err": "Missing required parameter: must provide either user_id or plan_key"
  What we've verified:
  - The same request without the version parameter returns 200 and renders the image correctly, so the token, file, and node are all fine.
  - It fails with any version ID, including the file's latest version, and with any format (svg, png).
  - GET /v1/files/:file_key?version=<version_id> works fine with the same token, so the version ID is valid and accessible.
  - We tried adding user_id as a query parameter and the error persists. Neither user_id nor plan_key is documented for this endpoint in the REST API reference, and the plan access tokens page doesn't list this endpoint as restricted.
  - The exact same request (including version) worked correctly before migrating from a personal access token.
  The error message looks like an internal attribution requirement leaking through the public API: version-pinned renders seem to require a user/plan context that plan access tokens don't carry, and there's no documented way to provide it from the client side.
  Questions:
  1. Is this a known limitation of plan access tokens, or a bug?
  2. If it's expected behavior, how should we pass plan_key (or equivalent) so that version-pinned renders work with a plan access token?
  Our use case: we render and cache node images per file version, so dropping the version parameter means we can no longer guarantee the rendered image matches the pinned version.
  Thanks!
Jaycee Lewis
Jun 11, 2026 6:36 PM UTC
Hey hey ​@FleetUI 👋 Thank you very much for the detailed post. I took this over to my API resources to get us clarity on what the expected behaviour is here. I’ll post back as soon as I get us a reply. Talk soon! — Jaycee
