Rushivar takhur
Aug 14, 2026 1:15 PM UTC
REST API 403 Error on v1/teams/:id/projects due to conflicting scope validation rules
Hello Team,
I am encountering a persistent 403 Forbidden error when trying to fetch the projects list for my team using a Personal Access Token via the REST API.
The endpoint I am targeting is:
GET https://figma.com
The Error Payload Received:
json
"status": 403,
"err": "Invalid scope(s): current_user:read, file_comments:read, file_comments:write, file_content:read, file_metadata:read, file_versions:read, library_assets:read, library_content:read, team_library_content:read, file_dev_resources:read, file_dev_resources:write, folders:read. This endpoint requires the projects:read scope"
Use code with caution.
Context & Technical Blockers:
  1. Scope Availability: The error message explicitly states that the endpoint requires the projects:read scope. However, when generating or managing my Personal Access Token (PAT) settings in the Figma account dashboard, the projects:read scope is not visible or available to select as a granular permission option.
  2. Conflicting Documentation: My token has been successfully configured with the modern granular scopes, including folders:read and file_metadata:read. However, the v1 endpoint refuses to accept these permissions, creating a catch-22 scenario where the endpoint demands a scope that cannot be assigned to a standard PAT.
Steps Taken to Troubleshoot:
  • Verified the Team ID matches my workspace exactly.
  • Confirmed the request is routed securely over HTTPS (://figma.com).
  • Attuned the token permissions to include all necessary granular read parameters.
Could you please clarify how a standard Personal Access Token can programmatically fetch the team's project listing under this current scope mapping structure, or if there is an alternative approach for our pipeline?
ksn
ksnSolution
Aug 14, 2026 7:50 PM UTC
Hey ​@Rushivar takhur  - thanks for checking over here. With our Updates to Figma’s file management, the structure has changed, and the API endpoints have also changed along with it.
I believe you’ve already taken that into consideration based on your post (mention updating to folders:read), but I wanted to note that to cover all bases.
I also saw that you had filed a support ticket on this as well (2072032). Since this is a more technical inquiry, I’ve surfaced your ticket with our support team to have someone reach out to you via email.
In the chance you haven’t been able to review some of these updated documents, here are some resources to help in the meantime:
- Folders endpoints (the replacements): https://developers.figma.com/docs/rest-api/folders-endpoints/
- Permissions reference (shows the full old-to-new mapping): https://developers.figma.com/docs/rest-api/scopes/
ksn
ksnSolution
