Josh22
Jul 26, 2024 9:20 PM UTC
Responsive mode in prototypes are broken
Why is the responsive mode in the prototype preview so broken? When you create a page with components and layers and set them to fill mode, everything fits to 100% width or height in the design editor. This reflects typical development as expected.
However, this doesn’t work in the prototype preview. When I set the prototype to responsive, sometimes it works, sometimes it doesn’t. For instance, I have a grid with cells. Those cells are set to fill. (In fact, everything in every layer is set this way). But when the prototype renders it breaks. Those cells sometimes are 100% the available area, other times they are set to their original rendered size from the frame.
For example, the cells are set to fill and happen to measure at around 200px wide because the main container (frame) fits all the content this way in design mode. But when it goes into the prototype preview with responsive mode, sometimes those cells take up the width appropriately, other times they revert back to what they are calculated at from the original main container.
Design: [ cell = fill ] (equates to ~200px or so)
Prototype: [cell = fill ] (may be 100% or may be ~200px)
Another issue, I get random fragmented lines on those cells that are not in the original styling. An artificial border that shouldn’t exist.
Jul 29, 2024 3:46 PM UTC
Hi!
It sounds like you’re experiencing issues with responsive mode in Figma prototypes. Here are a few suggestions to help resolve this:
  1. Ensure Consistency: Double-check that all components and layers are set to fill container properly in both design and prototype modes.
  2. Frame Settings: Verify that the frames containing the grids and cells are also set to responsive resizing. Sometimes, parent frame settings can affect child components.
  3. Prototype Setup: Ensure that the prototype’s device settings are correctly configured for responsive behavior.
  4. Check Constraints: Make sure all constraints (like left, right, top, bottom) are set correctly. Inconsistent constraints can lead to unexpected resizing.
  5. Update Figma: Ensure you are using the latest version of Figma, as bugs in responsive behavior might have been fixed in recent updates.
  6. Simplify Structure: Try simplifying the component structure to identify if a specific element is causing the issue.
If these steps don’t resolve the problem, consider reaching out to Figma support with your file for more specific assistance.
Good luck!
Marsy
Sep 25, 2024 10:18 AM UTC
me too experiencing the problem - responsive only work with very simple frames / everything just zooms proportionally not responsive (when i have components inside site frame)
Pavel_Kiselev
Power Member
Sep 25, 2024 11:17 AM UTC
Are they behave as expected in design mode? What happens when you resize your frames?
Marsy
Sep 27, 2024 9:07 AM UTC
I fixed this but NOT making the main frame with a flow a component (it was main component) - now its responsive again
trial
Nov 25, 2024 1:19 PM UTC
Responsive prototypes are very buggy and broken for me as well. I’ll manage to get everything working properly then the next time i load the project everything is off. And I know this is entirely Figma’s fault since all it takes to fix an element is to move it and undo then it magically works again. They’ve had these bugs for years now and honestly it’s extremely frustrating and and a huge waste of time,to the point that I will likely find an alternative to Figma.
Josh22
Josh22Author
Feb 27, 2025 4:04 PM UTC
Figured out the issue. Components do not update and recalculate their width or height when set to fill inside an auto layout frame. For instance, if I have a sidebar navigation at 1000px in height in the original component (because the main component frame has to be a static size) and bring an instance into a page using auto layout and set the height to fill, it sometimes works and sometimes doesn’t.
“Its a bug” - tell that to execs and shareholders looking at my prototypes as POC’s (pre-dev work). They don’t understand or care the reason why. Now we only finalize a POC with devs to avoid the countless issues with prototyping in Figma.
Paul_Palade
Jun 5, 2025 2:38 PM UTC
Hey ​@Josh22 has this issue persisted for you? I’ve run into the same buggy behavior with responsive prototypes where component instances are used. I’ve tried detaching them hoping that this will fix the issue but no. What’s set to fill will still revert to fixed. I think this is more frequent on mobile devices where browser memory seems to run out faster. Tested with Safari, Chrome, Brave and Firefox. Hopefully Figma will fix this limitation sometime into the future.
Josh22
Josh22Author
Jun 17, 2025 2:45 PM UTC
This is a 3+ year bug at this point. It has problems due to the way they calculate percentages in their code and the fact that when the canvas is first loaded, it runs an init() like function to run all necessary calculations at once. It’s probably an underlying architecture issue that can’t easily be fixed in a patch.
Catherine_Desrochers
Dec 4, 2025 5:55 PM UTC
Up : It still is massively broken
My page render perfectly 90% of the time, but sometime, it render completely broken like this (text blurred for privacy)
And, one again, 90% of the time, it will render properly… The problem here's quite big because it make user testings impossible in responsive mode
Paul_Palade
Dec 5, 2025 10:33 AM UTC
Hey ​@Catherine_Desrochers my most recent discovery is that responsive prototypes break when you have a flow starting point set. Removing it seems to solve the issue for mobile devices. The downside to that is you’ll be able to tap the left and right edges of the screen to navigate through your flow. And this is most likely not desirable...the tap zones are pretty wide, too. But it’s better than nothing. Will keep investigating! cc: ​@Josh22
