Yannick_Lung
May 11, 2026 7:30 AM UTC
Respect Screen Resolution When Dropping Images into the Canvas
When you drag a screenshot into the canvas, the display resolution is not taken into account.
For example, if a screenshot from an iPhone 17 Pro (1206 × 2622) is dragged and dropped into the canvas, it is inserted at a size of 603 × 1311 (i.e., half the actual size).
However, iPhone screenshots have a resolution of 144 × 144, or @3x. Accordingly, the screenshot size should be 402 × 874 (i.e., ⅓ of the actual size) when imported into the canvas.
Ralf
May 11, 2026 11:12 AM UTC
Found a workaround: When you use `Edit » Copy Screen` (cmd ctrl C) in the simulator app and paste that, the screen resolution is applied correctly.
I was always under the impression that screenshot PNGs from the iOS Simulator app have the correct DPI set via PNG metadata/EXIF data and the macOS Preview app showing the correct size when using `View » Actual size` , but this doesn’t seem to be the case (at least not on macOS Sequoia / Xcode 26.3 - might have changed on Tahoe). When I place a screenshot saved from the iOS iPhone 17 Pro simulator, it ends up at width = 1206 and height = 2622 and the metadata says 72dpi. So part of the problem might be the simulator not setting the correct metadata.
Ralf
May 19, 2026 6:52 AM UTC
Nope, `Edit » Copy Screen` also doesn’t apply the scale correctly, not sure why it worked when I tried this the last time. I also wondered if Figma would do apply the scaling correctly when the file is named like image@3x.png or has the PNG metadata set correctly (`sips -s dpiHeight 216 -s dpiWidth 216 image.png`), both didn’t do the trick.
