Erasmus
Jul 27, 2026 7:04 PM UTC
[Resolved] Copy file and export issue
Hi everyone
Figma file I’ve been editing for days and months as file owner.
Now I can’t seem to be able to copy elements on it, share the file, rename it etc. And this started immediately after an update.
I can design on the file but i can’t use AI features
Please can someone help me urgently? thank you!
[Moderator note: This post’s title was changed from Figma no working properly, after an update to [Bug] Copy file and export issue on 27-Jul-2026.]
Tom Reem
Tom ReemSolution
Jul 27, 2026 7:48 PM UTC
Hi ​@Jeyson Lopez — thanks for reporting this, and I've got some good news.
I checked in with our Engineering team, and they've pushed a fix. Copying and exporting should be working as expected now.
Give your tab a refresh and let me know how it goes.
I'm continuing to monitor reports and will follow up if anything changes.
Jul 27, 2026 9:14 PM UTC
Hi ​@Brian_Olson, thanks for reaching out!
I understand the frustration and how this must have slowed down your workflow. I merged your topic with this similar, related one in the Community. This was a bug that our team has now pushed a fix for. Please refresh your tabs and let us know if you run into any further issues.
Johnsmith99
Jul 30, 2026 6:04 AM UTC
Thanks for the update, Tom. I was experiencing the same issue where I couldn't copy or export files even though I still had editing access, so it's good to hear the engineering team identified and fixed it.
After refreshing the tab, everything seems to be working normally again. Really appreciate the quick response and the follow-up on this. It saved a lot of confusion.
Walter Clayton
Jul 30, 2026 1:55 PM UTC
It’s fixed on my side thank you!
Joann Zhang
Aug 25, 2026 2:55 AM UTC
facing the same issue
Celyn_L
Aug 25, 2026 5:46 AM UTC
Hey ​@Joann Zhang, thanks for reaching out! I understand you’re currently experiencing the same issue.
Since the original issue was resolved, could you confirm which actions aren’t working for you and share a screenshot of any error message you see?
It would also be helpful to know whether this affects all files and whether you’re using the browser or desktop app.
Thanks!
YPM
Oct 26, 2026 2:45 PM UTC
​@Tom Reem
Hi,
I’ve been experiencing a recurring issue in Figma. I keep getting the error message “You are not allowed to copy this file,” even though I am the file owner.
To resolve it temporarily, I toggle the “Viewers can copy, save, and export from this file” setting if it’s enabled, I disable it, and if it’s disabled, I enable it. However, whenever I return to the file after a day or so, the same error appears again.
Could someone please help me find a permanent solution to this issue? I would also appreciate it if the Figma development team could investigate and fix this recurring bug.
Thank you for your help!
