James_Pai
Jun 15, 2021 12:44 AM UTC
Resolve conflicts doesn't do anything, can't merge
I’m trying to merge changes back from a branch and I’m being prompted to resolve conflicts first. However when I hit “Resolve conflicts”, the dialog just closes and nothing happens. If I try again, I get the same screen with the same message so I’m unable to merge anything. Is this a known issue?
Alex_Xu
Jun 15, 2021 5:05 PM UTC
Hi James,
Sorry for the inconvenience! This may be related to a known issue—are you working on a branch which has been restored since a merge into main? If so, we are looking into the issue, and must recommend that you work on a new branch.
If not, I will follow up with you privately to learn more! Thanks for holding tight!
Jonghee_Woo
Aug 26, 2021 2:17 AM UTC
Has this issue solved yet? I’m struggling same issue now.
lola_dupey1
Sep 14, 2021 8:15 AM UTC
Hi! Is it resolve? I’ve the same issue now, thank you!
Dave_House
Sep 22, 2021 10:22 AM UTC
Same issue here, pressed resolve and am taken to library without my changes and then it applies them 30-1m later but has no conflicts. After I did this once the number of conflicts actually went up from 1 to 2.
James_Pai
James_PaiAuthor
Sep 22, 2021 10:05 PM UTC
My original issue seemed to resolve itself after being stuck for a 3-4 weeks, but I didn’t do anything in particular to fix it. Not sure what happened!
Kyle_Goodwin
Nov 3, 2021 5:25 PM UTC
I have a similar issue when trying to resolve conflicts. The progress bar gets to the end and then just sits there. I have to restart Figma to get out of it.
Jean-Christophe_Besson
Nov 5, 2021 9:55 AM UTC
I have this kind of issue too. Despite several update of Figma. Each time the update couldn’t be done because of a conflict I couldn’t resolve. When I tried to update the branch from master or resolve the conflict I got a grey full screen. Sounded like a great old windows blue screen 😃
HonzaTmnProductboard
Nov 10, 2021 10:19 AM UTC
The same problem as Jean, there is a console error:
Alex_Thurman
Jul 4, 2022 1:09 PM UTC
Now I’m also having this problem. Just need to fix 1 conflict before I can merge but the dialog box keeps crashing!
Alex_Thurman
Jul 5, 2022 7:03 AM UTC
Were you able to find a solution for this? I’m getting no response from @Figma_Support
