james-anyteam
Mar 18, 2026 3:35 PM UTC
Replacing existing components with slots does not trigger change in shared library
I’m updating a shared design library to add slots. I previously had placeholder “slots” that I’m now replacing with the new/actual slots feature. When I replace the placeholder with a slot, the publishing menu is not triggering a change to enable me to publish the library updates.
I’ve tried changing other parts of the same component to trigger a change (e.g., add new lines of text, change font size/weight), but nothing seems to trigger a change. I made updates to another component in the library and it did trigger a change, however, my previous changes are not reflected in this update, so I still cannot publish the slot changes I made (which is my goal). I’ve tried reloading tabs multiple times as well, but nada.
See video for more context:
Re_Mago
May 18, 2026 10:09 AM UTC
It’s happening to me as well. Did you find a way to fix this?
