Kevin Gallardo
Oct 1, 2025 4:01 PM UTC
Remote MCP server OAuth client registration issue
Hello, I am trying to run through the MCP OAuth protocol to register a client on the Figma remote MCP server, running into an issue when calling the registration endpoint.
After discovering the registration endpoint via the /.well_known/oauth-authorization-server call, I call the registration endpoint via:
curl -sS -v -X POST "$REG_ENDPOINT" -H "Content-Type: application/json" -d '{
    "redirect_uris": ["http://127.0.0.1:53195/callback"],
    "grant_types": ["authorization_code","refresh_token"],
    "response_types": ["code"],
    "token_endpoint_auth_method": "none"
I get back from this a “Forbidden” response and without this response I can’t continue the OAuth protocol.
Does client registration have limitations to prevent it from working on different domains and url callbacks at the moment? I am doing this in a context outside of Claude, Cursor, etc..
bcheidemann
Jul 7, 2026 12:35 PM UTC
> I’m not sure what the reason would be for whitelisting clients in this particular method. The industry wide norm is to let any MCP client connect to your MCP server, it’s also the reason why this is an open protocol.
+1
I'm trying to use your remote server with Zed, which currently only has support for the local server. This feels totally arbitrary and is honestly pretty frustrating.
bcheidemann
Jul 8, 2026 11:36 AM UTC
Hey, I’m currently unable to use the Figma MCP with Zed on Linux, because it only supports the local MCP via the Desktop app. However, the Desktop app is unavailable for Linux…
Marek KALNIK
Jul 9, 2026 9:45 AM UTC
Opencode is also blocked.
Jesse_Clark1
Jul 15, 2026 7:23 AM UTC
Also here for Opencode :/
ksn
Jul 15, 2026 5:28 PM UTC
Hey all - we hear you, and know you’d like to see an expansion of our availability for other MCP servers.
At this time, we don’t have an update on when/if there will be acceptance/support of any additional ones at this time, but we do encourage you (and anyone else that may come across this) to continue requesting via the links Tom confirm above.
Thank you for your patience.
Benoit R
Jul 16, 2026 8:59 AM UTC
Adding on the pile: Copilot Desktop. Copilot CLI works, no fuss, but product and design adoption of CLI tools is not the easiest at all. Copilot Desktop offers to use SSE, but the SEE MCP does not have the “use_figma” tool...
Mariano Gutierrez Xavier
Aug 18, 2026 3:10 PM UTC
Same here, getting blocked with GitHub Copilot App
Pranit Harekar
Aug 19, 2026 4:06 PM UTC
GitHub Copilot Desktop App throws the following error when signing in -
Authentication failed
figma: RPC error -32603: Request session.mcp.oauth.login failed with message: Client registration failed: server responded with status 403 Forbidden: Forbidden
Adding HTTP or SSE manual server doesn’t work either. All we need is for GitHub Copilot Desktop App to be able to grab screenshots directly from Figma files.
Any ETA on this?
Tom Reem
Sep 9, 2026 9:10 PM UTC
Hey ​@Pranit Harekar ​@Mariano Gutierrez Xavier ​@Benoit R — Copilot Desktop has been the common thread for the three of you, and I checked in with the product team on it. Here's a solution that's unblocked others who ran into a similar scenario.
  1. Install the GitHub Copilot CLI and authenticate with Figma through it.
  2. Open the Copilot Desktop App.
  3. Install the Figma plugin.
Run them in that order. We’ll continue to share more information as details become available. 🙏🏻
