Carlos_Pires
Mar 19, 2026 11:52 PM UTC
Remote mcp generate_figma_design in Claude Code always fails with "Couldn't send to Figma"
The result is always the same:
  1. On the browser, the error message “Couldn't send to Figma"
  2. On Figma, a new completely blank file
  3. On Claude Code the mcp outputs “ Status for capture ID `d1ecf357-9ddb-4ecf-b704-c813feb3063e`: **processing**. “ in an endless loop
It NEVER works. Copying and pasting does, but that’s not much help. The whole point here is to have Claude moves stuff around, not people.
Has anybody managed to get this thing working?
Even a simple HTML/CSS page with no JS whatsoever fails.
Mar 24, 2026 3:43 AM UTC
Hi ​@Carlos_Pires,
Thanks for bringing this to our attention.
I’ve passed this post along to our team to see if there are any workarounds or troubleshooting steps to try.
I’ll let you know if I receive any updates from them.
Carlos_Pires
Mar 30, 2026 12:52 PM UTC
Update:
I managed to get this to work. There are probably 2 issues here:
  1. My first attempts were using a page with embedded mermaid charts that were being rendered with mermaid script loaded from CDN. So I figure either there is an issue with the page render time or the size of the rendered page with all the CSS and SVG bloat from the default mermaid rendering.
  2. There is also probably some kind of rate limiting, because subsequent attempts with simple skeleton HTML were systematically failing too.
Because I suspected the above, I waited for a while and then it worked with the simple HTML pages. Then I developed a simple mermaid SVG renderer instead of using the original mermaid rendering script, and that solved my original problem. This reinforces my belief that these 2 issues exist. Which is a bummer because of no proper error reporting. If the API returned an error message that clearly identifies the problem, then it would have been simple to arrive at the solution. Instead, I had to navigate in the dark and I guess others will too.
Hani Khan
Apr 20, 2026 5:54 PM UTC
I am also experiencing this. I am trying to send a screen to figma using Figma MCP and the generate_figma_design keeps hanging and getting stuck in a loop and then i get the message “Couldn’t send to Figma”. The ‘copy instead’ button is not a good work around for me because I need my SKILL.md file to guide the generation of that screen in figma so it uses Figma components.
adamsmasher
Apr 23, 2026 6:54 PM UTC
Hi ​@Hani Khan and ​@Carlos_Pires - stepping in for ​@Junko3.
I also took your additional feedback to our team for review. ​@Hani Khan, have you tried specifically asking Claude Code to use use_figma with the /figma-use skill and as well as your own SKILL.md? I’m wondering if that will get you what you need rather than using the copy button.
In the meantime, I’ll reply again if I hear anything from the team!
Aayushi
Figma Ambassador
Figma Ambassador
Jun 18, 2026 6:55 PM UTC
Couldn't send to Figma usually means the connection between Claude Code and Figma desktop broke mid-session rather than a permissions problem. A couple of things that cleared it for me: make sure Figma desktop is open with the file active and a frame actually selected before triggering anything; the write tools need an active canvas, not just a running process. And if it keeps failing, remove the Figma connector from Claude Code completely and reconnect from scratch rather than just toggling it. Write tools seem to need a cleaner connection than read tools do. Does it fail right away or after a delay?
Disclosure: I’m part of Figma’s Forum Ambassador program.
Maxym
Aug 26, 2026 7:39 AM UTC
This looks like an MCP connection or rendering issue, and the troubleshooting shared above may solve it.
For the separate task of importing the same local HTML/CSS page into editable Figma layers without MCP, you could try Source → Design. Disclosure: I built it. It accepts an HTML file or a complete frontend project ZIP and performs the rendering through Chromium.
It is not a replacement for component-aware MCP editing, but it may be useful as an import fallback.
Plugin: https://www.figma.com/community/plugin/1671982756700161071
