Yusuf Yilmaz
Feb 17, 2026 11:13 AM UTC
Remote Debugging Port Behavior Change Between 126.0.4 and 126.1.2
Hello Figma Team,
I’ve noticed a behavior change after a recent update and wanted to check whether this is intentional or a regression.
Environment
  • macOS (Apple Silicon / arm64)
  • Figma Desktop
  • 126.0.4 → Remote debugging works
  • 126.1.2 → Remote debugging no longer works
What I’m Observing
When launching Figma 126.0.4 with: open -na "Figma" --args --remote-debugging-port=9222  the remote debugging endpoint binds successfully.
Verified with: lsof -nP -iTCP:9222 -sTCP:LISTEN
Example output (working case on 126.0.4):
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
Figma 60295 yusuf.yilmaz 35u IPv4 0x2ad77ac47c7d47b7 0t0 TCP 127.0.0.1:9222 (LISTEN)
However, after updating to 126.1.2, using the exact same launch command:
the port no longer binds.
Running: lsof -nP -iTCP:9222 -sTCP:LISTEN
returns no listening process.
Downgrading back to 126.0.4 immediately restores the behavior.
Additional Context
  • App is properly signed and notarized.
  • No firewall or system-level restrictions.
  • spctl --status shows assessments enabled.
  • Behavior change appears specifically after the 126.1.x update.
And another information is:
When I install Figma using: brew install --cask figma  it installs a working version (e.g., 126.0.4) where the --remote-debugging-port=9222 flag functions correctly. However, shortly after launching the app, Figma’s internal auto-update mechanism automatically upgrades the app to version 126.1.2. After this update, the --remote-debugging-port flag no longer works and port 9222 is no longer exposed. As a result, even if I intentionally install a known working version via Homebrew, I cannot maintain a stable debugging setup because the in-app auto-update overrides it.
We just wanted to confirm:
  • Was --remote-debugging-port intentionally disabled or restricted in 126.1.x?
  • If so, is there an officially supported alternative for local DevTools Protocol access?
  • Or could this be an unintended regression?
Thanks in advance for the clarification.
Jefferson Costa
Feb 19, 2026 4:55 PM UTC
Figma 126.1.2 explicitly strips the --remote-debugging-port switch on startup:
app.commandLine.removeSwitch("remote-debugging-port")
This line is absent in 125.2.3.
Why they did this?
