Anthony Michon
Nov 19, 2026 4:00 PM UTC
Referenced Library that is not associated with file
In my design system file, there is a referenced & binded library file that is attached & visible under my Apply Variable Mode menu on the right hand side; the file referenced is in my drafts. I need it removed, no longer referenced in my design system file. When I go under manage libraries in my design system library the referenced library file is not shown, so therefore I cannot remove it. Is there another work around for me to remove it?
I no longer need the referenced library at all. Since it is in my Drafts location, I’ve even tried deleing it from there, reseting Figma and when opening my design system file again, it is still being referenced. Please help.
Anthony
michon.anthony@gmail.com
kmeza
Figma Ambassador
Figma Ambassador
Nov 19, 2026 5:20 PM UTC
Hi Anthony!
Why it’s still showing up
The “Apply variable mode” menu doesn’t come from the libraries enabled in Manage libraries. It comes from variable collections the file still has a reference to. That reference can stay even after the library is gone, usually because:
  1. Some layers still have variables from that library bound to them (fills, spacing, radius, etc.), or
  2. Some frames, sections, or pages still have a mode from that collection applied to them.
That’s also why deleting the drafts file didn’t help. Your design system file holds its own copy of the reference, so deleting the source just turns it into a “missing” library.
Things to try
  1. Restore the drafts file from Trash first. It’s easier to clean up while the source still exists. If it’s back and published, it should appear in Manage libraries so you can use Swap library or remove it properly.
  2. Clear any applied modes. Go page by page and select the page itself (click an empty spot on the canvas), then your top-level frames. In the right panel, look for a mode from that collection under Layer / Apply variable mode, and set it back to Auto or remove it. Don’t forget components and variants, since a mode set on a main component is easy to miss.
  3. Find layers still using its variables. Check Manage libraries → Used in this file (look under missing libraries too). Variable-finder plugins from the Community can also scan the file and list bound variables by collection, so you can detach or remap them.
  4. Reload the file after cleaning up. Sometimes the menu doesn’t refresh until you do.
If it’s still there after all of that
There’s a known issue where a collection from a removed library stays in the mode picker even when nothing in the file uses it anymore. Other members have reported the same thing. If you’re sure nothing is bound and no modes are applied, it’s worth reporting to Figma Support (help.figma.com → Submit a request) with a link to the file so they can look at it on their end.
Let us know how it goes!
Come learn Figma with me! https://maven.com/katie-meza/figma-for-brand | Disclosure: I’m part of Figma’s Forum Ambassador program.
