Antoine.b
Aug 5, 2026 1:23 PM UTC
Question about upgrading from Figma Make to Figma Design
Hello,
I created a project using Figma Make on the free Starter plan.
Before upgrading to a Professional Full Seat, I would like to confirm something.
If I upgrade my account, will I be able to:
  1. Open or copy my existing Figma Make project into Figma Design?
  2. Edit it as a regular Figma Design file (editable layers, text, shapes, Auto Layout, etc.)?
  3. Export it as a PDF from Figma Design?
More specifically, I want to know whether upgrading will work with my existing Figma Make project, or if this functionality only applies to projects created after the upgrade.
Thank you for your help.
Best regards,
    Gayani_S
    Gayani_SSolution
    Aug 5, 2026 2:49 PM UTC
    Hey ​@Antoine.b, thanks for reaching out! Good thing to double-check before you upgrade, here's how it breaks down:
    1. Bringing your Figma Make project into Figma Design: Yes, this is possible using the Copy design feature inside Figma Make. From the preview of your Figma Make file, get to whichever page or state you want to bring over, then click Copy design at the top of the preview. It converts that view into a collection of design layers you paste onto the canvas of a Figma Design file. Full steps here: Copy a Figma Make preview as design layers.
    2. Editing it like a regular Figma Design file: Once pasted, yes. Those layers behave like any other layer in Figma Design. You can restyle, resize, edit text, rearrange, and apply Auto Layout just like anything built natively there.
    3. Exporting as a PDF: Also yes, and nothing Make-specific here. Since it's now a normal Figma Design file, you'd use Figma Design's standard export flow (select your frames, then use the Export section in the right sidebar to add a PDF configuration).
    On whether this works with your existing project specifically: yes, it will. When you upgrade, you're upgrading a specific team (not just your account), and that covers every file already sitting in that team, not just files created afterward. So as long as you upgrade the same Starter team your Figma Make project currently lives in, it'll be covered automatically. (Just double check you're upgrading that same team, rather than starting a brand-new one, since the paid features only apply to the team you actually upgrade.)
    A few things worth knowing going in:
    • Copy design captures a snapshot of whatever page/state you're viewing. For a multi-page app, you'd repeat this once per page.
    • The design layers aren't linked back to your Figma Make file, so edits on one side won't sync to the other.
    • They're not automatically tied to your design system. You'll manually connect components and styles once pasted in.
    • Interactive behavior (like a dropdown) comes across as a static layer, not a working interaction.
    Hope that clears things up!
    Gayani_S
    Gayani_SSolution
    Luka yakymchuk
    Sep 17, 2026 2:22 PM UTC
    try this free plugin: figma.com/community/plugin/1681329593603309826
    workflow:
    1. open the file where your variables and components live, run the plugin, hit scan.
    2. expert your Figma make into html, they still don't support link import
    3. then in your working file drop the html, pick which system to bind to, import.
    buttons/inputs/cards come in as instances of your variables, saves life of work
    Sarah Shelley
    Oct 8, 2026 11:54 PM UTC
    For editable layers specifically: Make's "Copy design" gives a static snapshot without auto layout or components. I built a plugin, Relay, that takes the project .zip from Make's Code tab and rebuilds it as editable frames with auto layout, components, variables and prototype links, which you can then export as a PDF. It's free to try, one screen at a time. (I'm the maker.)
    https://www.figma.com/community/plugin/1689869264291769693
