David_Brien_Swann
May 30, 2025 12:24 AM UTC
Publishing failed: Please reload the page to publish
Getting the “Publishing failed: Please reload the page to publish” error when I try to publish.
I’ve gone through the older treads but haven’t found a solutions beside Figma sent out a fix. I’ve tried everything I can think of including the obvious solutions like reloading tab and restarting computer.
I’ve tried deleting all new components and even restored earlier versions, from the version history panel, that were previously published. Yet still no luck. My other libraries will publish, but my main library will not. 🙄
nini_dai
May 30, 2025 1:38 AM UTC
I’m experiencing the same issue, tried different things but no luck.
Nathan7
May 30, 2025 2:00 AM UTC
Our company is facing the same issue. :-(
cloudyrobin
May 30, 2025 4:09 AM UTC
I have a component library that I has previously been published. I am trying to publish it again with more changes, but after clicking the publish button it says "Publishing failed. Please reload the page to publish".
I have tried reloading, I have tried rolling back to a version that was successfully published, I have tried publishing from the web client instead of the app, I have tried publishing one component at a time, and even tried to unpublish the library, which also didn't work.
Anyone ever had this happen before? I'm tearing my hair out.
Chrystal Ho
May 30, 2025 6:43 AM UTC
I’m also facing the same issue.
petebarr
May 30, 2025 7:35 AM UTC
Same here. It’s only happening to 1 library that’s quite big strangely. I reverted back to when the library was previously publishing and even back to when the file was first created but still getting the failure error.
May 30, 2025 7:38 AM UTC
Hi there, Thanks for reporting this!
This might be related to an ongoing bug that our team is already aware of. Once we have more details on this, we'll be sure to update.
We really appreciate your patience as we work on this.
alex_duong
May 30, 2025 7:41 AM UTC
I have a problem with figma file when publishing my library. I have closed and reopened the file and figma many times but still have this problem. It affects the progress of my project. Please fix it quickly.
alex_duong
May 30, 2025 7:42 AM UTC
Me too. I can't be calm right now. 🙄
Gayani_S
May 30, 2025 11:49 AM UTC
Hey everyone, thank you for your patience while the team was investigating this issue!
Our engineering team have deployed a fix for this issue now, can you please refresh the browser/restart the Figma app, and check if publishing is working for you now?
Apologies for any disruption that was caused by this - please do let us know if you experience any issues when trying to publish now.
David_Brien_Swann
May 30, 2025 5:08 PM UTC
Tried updating this morning was able to successfully publish. Hopefully this issue is resolved. Anyone else able to successfully publish?
