FS Ahmed X 2
Feb 23, 2026 9:33 PM UTC
Publish was unsuccessful
I cannot publish my work anymore. It says “Publish was unsuccessful - try again later or contact support”. Is this related?
I have the same issue as well as Update attempt was unsuccessful. It worked fine until this morning.
    Celyn_L
    Mar 2, 2026 3:34 AM UTC
    Hi ​@FS Ahmed X 2 — Celyn here from Figma Community Support. Welcome to the forum!
    Thanks for flagging this. I understand your update attempt in Figma Make was unsuccessful — are you still experiencing this issue?
    If so, could you try duplicating the Make file and publishing the duplicated version to see if the issue persists?
    You can also try publishing from a different browser or from the desktop app (if you’re currently using Figma on web).
    If the issue continues, please submit a bug report so our team can investigate further. To do that:
    • Go to the Support Hub
    • Click Start a chat
    • Type “Report a bug”
    • Share the impacted file with support-share@figma.com and grant “Can View” access
    This allows us to reproduce the issue and investigate with our Engineering team.
    Let me know if there’s anything else I can help with!
