UserFiore
Apr 30, 2026 7:31 PM UTC
Publish button is missing, I am on the pro plan
I am on the pro-plan and I published like 10 minutes ago and was about to do it again, but my publish button is now missing, but I am on a pro plan?
May 1, 2026 12:54 AM UTC
Hi ​@UserFiore,
I understand you're looking for the Publish button to update your published project.
If you're not seeing the "Publish" button next to the "Share" button, please try the following:
  1. Click the "Share" button
  2. The modal that appears is split into two sections — in the lower "Publish" section, click "Update"
The help article Update a published functional prototype or web app doesn't seem to explicitly mention this at the moment, but it appears this is one way you can update your project, based on what I was able to test on my end.
I'll pass this feedback along to our team internally.
Hope this helps!
Pragati Singh
May 22, 2026 12:10 AM UTC
 is there a limit on how many times one can publish? I made changes to a component and now the publish button does not appear.
May 22, 2026 11:04 AM UTC
Hey ​@Pragati Singh ,
There are no limits on how many times you can publish/update a Figma Site. Regarding the publish button disappeared after updating a component, here are a few quick things worth trying:
  • Refresh the browser/file completely, then try publishing again
  • Make sure any library/component updates were accepted in the Figma Site file
  • Confirm you still have edit/publish permissions (on paid plan, and it requires edit access to the file)
I’d also recommend checking our Help Center article: Publish, update, or unpublish a site.
If the Publish button is still missing after that, I’d recommend submitting a bug report so the team can investigate the file directly. To do that: Go to the Support Hub / Type “Report a bug” / Click Start a chat
Please also include:
  • the affected file URL
  • screenshots of the missing Publish button/state if possible
  • and grant “Can View” access to support-share@figma.com so the team can take a closer look at it
Thanks!
