Mona5
Sep 28, 2026 6:21 PM UTC
Prototype rendering issue
Hello,
I’m experiencing a serious issue with my Figma file, all images are visible correctly on the main file (figma canvas) but no longer appear in Prototype/Present mode.
This issue is currently blocking my work and has a direct impact on my project, so I would appreciate your help in treating this as a priority.
The important point is that the Prototype was working perfectly before I started working with Figma Make. All images, logos, cards, and other visual elements were rendering correctly in Preview/Present mode.  After working on the project, the issue appeared.
I initially suspected that Figma Make or my Visual Studio workflow might have caused it, so I tested older versions of the file from before the Figma Make work. However, the same issue now occurs even in those older versions.
I have already tested:
* Chrome, Incognito mode and another browsers
* Another device
* Different networks
* Older versions of the file
* Removing scrolling and fixed positioning
* Clip content OFF
* Auto Layout ON/OFF
The key finding is that
when I remove Auto Layout from the main `Sections` container, or add image not in the auto layout the images immediately appear in Prototype mode.
However, this breaks the entire page layout, so it is not a usable solution. The prototype interactions and marquee animation also work; it is mainly the image rendering that is failing.
IMPORTANT NOTE:
This was working correctly before, so I believe something changed in how this file is being rendered in Prototype/Present mode.  Could you please investigate whether this is a Figma Prototype rendering issue or a problem with the file itself?  I can provide the file link and any additional diagnostic information you need.
Thank you
Jaycee Lewis
Sep 28, 2026 11:42 PM UTC
Hey ​@Mona5 👋 Thanks for reporting this. I opened a support ticket for this. The ID is 2158677 and the email subject line is Images disappear in Prototype mode inside Auto Layout container. Please keep an eye on your email (and spam folder if necessary) for the email and any replies from our team. Thanks again! — Jaycee
