asmitaj
Feb 13, 2025 5:20 AM UTC
Prototype Preview Issues – Seeking Community Help
Question:
Hi Figma Community, I'm encountering an issue with my prototype. While everything appears correctly on the design canvas, some interactions or elements don't work when I preview it. Has anyone experienced this before, and could you offer any insights or solutions? Thanks!
Feb 13, 2025 6:05 AM UTC
Hi there,
Thanks for reaching out. Could you elaborate a little bit more details about the issue please? I hope I can investigate it further!
Toku
StanleyJames
Feb 13, 2025 6:11 AM UTC
Hey there! I’ve run into similar issues before. It sounds like some interactions or elements might not be fully linked in your prototype. Double-check your triggers, interactions, and make sure everything is properly connected. Also, check if any layers or frames are hidden or locked, as they can prevent interactions from working. If you're using components, ensure that states are set correctly for each one. It might also help to test in different browsers or reset the prototype to rule out any glitches.
