Hi all, following up with an update. Sorry to hear you’ve encountered trouble with this as well, @Vitalii Nikiforov.
A similar issue was reported in this thread: Default variant interaction changes when a published component from a library is used in a new file. There, a variant interaction worked in the library file, but on instances placed in other files, it lost its link. We escalated that report to our engineering team. They investigated it using the files that were shared with us, and a fix recently went out.
To help us see where each of you stands, could you let me know:
- Does that match what you're seeing? Please have a look at the other thread and let me know whether it sounds like the same problem or something different.
- Is it still happening? Let me know if it happens again after your next library update.
If it's still happening, file access will let us confirm whether it's the same issue or something that needs a closer look:
- @David_Chung, reply to the email for case: 2085476, with the file URLs, and give support-share@figma.com view access.
- @Luongnd and @Vitalii Nikiforov, please submit a request via the Support Hub → Report a bug. Include the file URLs and a link to this thread. Vitalii, your post came after the fix went out, so your files would be especially helpful.
And if it's working for you now, a quick reply saying so helps just as much. 🙏🏻
