Arbuz Tv
Apr 29, 2025 6:29 AM UTC
Problem during installing Figma
Hello everyone. Here is a problem during installing Figma on Windows. Can someone help me?
[29.04.25 14:22:17] info: Program: Starting Squirrel Updater: --install .
[29.04.25 14:22:17] info: Program: Starting install, writing to C:\Users\Administrator\AppData\Local\SquirrelTemp
[29.04.25 14:22:17] info: Program: About to install to: C:\Users\Administrator\AppData\Local\Figma
[29.04.25 14:22:17] warn: Program: Install path C:\Users\Administrator\AppData\Local\Figma already exists, burning it to the ground
[29.04.25 14:22:18] info: CheckForUpdateImpl: Reading RELEASES file from C:\Users\Administrator\AppData\Local\SquirrelTemp
[29.04.25 14:22:18] info: CheckForUpdateImpl: First run, starting from scratch
[29.04.25 14:22:18] info: ApplyReleasesImpl: Writing files to app directory: C:\Users\Administrator\AppData\Local\Figma\app-125.4.6
[29.04.25 14:22:20] info: LogHost: Rigging execution stub for Figma_ExecutionStub.exe to C:\Users\Administrator\AppData\Local\Figma\Figma.exe
[29.04.25 14:22:21] info: ApplyReleasesImpl: Squirrel Enabled Apps: [C:\Users\Administrator\AppData\Local\Figma\app-125.4.6\Figma.exe]
[29.04.25 14:22:22] info: ApplyReleasesImpl: Starting fixPinnedExecutables
[29.04.25 14:22:22] info: ApplyReleasesImpl: Fixing up tray icons
[29.04.25 14:22:22] warn: ApplyReleasesImpl: Failed to delete key: C:\Users\Administrator\AppData\Local\Figma\Figma.exe: System.UnauthorizedAccessException: Не удалось выполнить запись в раздел реестра.
   в System.ThrowHelper.ThrowUnauthorizedAccessException(ExceptionResource resource)
   в Microsoft.Win32.RegistryKey.EnsureWriteable()
   в Microsoft.Win32.RegistryKey.DeleteValue(String name)
   в Squirrel.Utility.LogIfThrows(IFullLogger This, LogLevel level, String message, Action block)
[29.04.25 14:22:22] warn: ApplyReleasesImpl: Couldn't rewrite shim RegKey, most likely no apps are shimmed: System.UnauthorizedAccessException: Не удалось выполнить запись в раздел реестра.
   в System.Collections.Generic.List`1.ForEach(Action`1 action)
   в Squirrel.UpdateManager.ApplyReleasesImpl.<unshimOurselves>b__13_0(RegistryView view)
[29.04.25 14:22:22] info: ApplyReleasesImpl: cleanDeadVersions: checking for version 125.4.6
[29.04.25 14:22:22] info: ApplyReleasesImpl: cleanDeadVersions: exclude new version folder app-125.4.6
[29.04.25 14:22:22] info: Program: Finished Squirrel Updater
    Apr 30, 2025 2:10 AM UTC
    Hi ​@Arbuz Tv, thanks for reaching out!
    I appreciate you sharing the log file. To help you further with this, I'm going to create a support ticket for you using the information you've provided.
    Our support team will reach out to you directly to assist you with this matter. Please keep an eye on your inbox—you should receive an email about the new ticket shortly. It will be sent to the email address associated with your account.
    Thanks again for reaching out!
