Silvio Jäger
May 27, 2026 1:40 PM UTC
POST "/v2/webhooks" does not respond - timeout
We use the v2 API to set up webhooks, and it worked fine until about a week ago.
Now, setting up new webhooks through the API runs into a timeout.
Example request:
"event_type": "FILE_UPDATE",
"team_id": "111111111111",
"passcode": "PASSCODE",
"endpoint": "https://my-webhook-target-url"
The request times out with no response from the endpoint.
Is this a known issue?
Thanks, Silvio
Jaycee Lewis
May 27, 2026 10:35 PM UTC
Hey ​@Silvio Jäger 👋 Thanks for the detailed report. I'm able to reproduce this on my end and want to confirm we're seeing the same thing.
Running this from my machine against a team I own:
curl -i -X POST https://api.figma.com/v2/webhooks \ -H "X-Figma-Token: <my PAT with webhooks:write>" \ -H "Content-Type: application/json" \ -d '{ "event_type": "PING", "team_id": "<my team_id>", "endpoint": "https://webhook.site/<test endpoint>", "passcode": "test123" }'
  • Hangs for ~30s, then returns HTTP 504 Gateway Timeout from CloudFront
  • No webhook is created
  • a follow-up GET to /v2/teams/{team_id}/webhooks returns an empty array
  • a GET on the same v2 path with the same token returns 200 in ~200ms
Seems like the token, scope, and team access are all fine.
To make sure I’m chasing the same challenge, could you confirm a couple of things?
  • Does a GET to https://api.figma.com/v2/teams/{your_team_id}/webhooks return 200 for you with the same token you're using for the POST?
  • If you swap event_type to PING (or vice versa, if you've only tried FILE_UPDATE), does the behavior change at all?
  • Do you have a CloudFront request ID or x-figma-rest-api-request-id from any of your timed-out attempts?
  • Including -i in your curl will surface those in the response headers
Thanks for the additional details! — Jaycee
Silvio Jäger
May 28, 2026 7:15 AM UTC
Hey Jaycee
Thanks for the fast response!
Yes thats exactly what i get on my end as well.
GET and DELETE endpoints work fine. Responses in around 300ms.
To your additional things:
- Yes GET returns 200. My PAT has webhook:read and webhook:write access.
- Just swapped to PING now → unfortunately same result
- Yes. Here is one:
Generated by cloudfront (CloudFront) HTTP3 Server
Request ID: M34diuCqaNY2oYdkkLm4u7b6TBMcW66gmAzz4ohH72a3b49NFhMEXA&#x3D;&#x3D;
Thanks, Silvio
Simon Forster
May 28, 2026 1:32 PM UTC
Hey, I’m having the exact same issue since yesterday. Here’s the another request ID if needed.
Request ID: KnSrQ5XnEvRmdRFWnfyXHhdlFDpQyOaeSZ9Kw17ojYJiemBakMUJAg&#x3D;&#x3D;
Simon P Forster
Jaycee Lewis
May 29, 2026 10:12 PM UTC
Thanks ​@Simon Forster and ​@Silvio Jäger 🙌 I took this to my internal resources and will follow up if I have an update for us. — Jaycee
