rec_intra
Nov 4, 2026 2:37 PM UTC
PNG export fails on Google Drive for desktop after updating to 126.11.7 (Windows)
Hello,
After Figma Desktop auto-updated to version 126.11.7 (Windows), I can no longer export PNG files directly to a folder in Google Drive for desktop (virtual drive G:, a Shared Drive).
Steps to reproduce:
1. Open any file in Figma Desktop 126.11.7 on Windows.
2. Select a frame and export it as PNG (1x).
3. In the save dialog, choose a folder in Google Drive for desktop (e.g. "G:\Drives compartilhados\...").
4. The export fails with the error: "Failure to save the file. '<filename>.png' could not be saved. The remaining files will not be saved."
What I already checked:
- The destination folder exists and I have write permission (other apps save there normally).
- No file with the same name exists, the path is short (163 characters), and there is enough disk space.
- Exporting the same frame to a local folder (Desktop) works fine.
- Launching the previous version (126.10.13) still installed on my computer, the export to the same Google Drive folder works perfectly. So the problem started with version 126.11.7.
Environment:
- Figma Desktop 126.11.7 (broken) / 126.10.13 (works)
- Windows 11 Home 10.0.26200
- Google Drive for desktop (Shared Drive mounted as G:)
This is a major blocker in my daily workflow, since I export approval files directly to our shared drive. Screenshot of the error attached.
Thank you,
Renan
    adamsmasher
    adamsmasherSolution
    Nov 7, 2026 6:51 PM UTC
    Hello everyone! Thank you for your patience while our engineering team looked into this issue. We’ve released a fix for it, so please update the Figma desktop app for Windows to the newest version (v126.11.8, and for the Beta app v126.12.2).
    Let us know if you have any further trouble!
    CeciliaGonçalves
    Nov 4, 2026 4:21 PM UTC
    Same issue here. After Figma Desktop updated to 126.11.7, PNG export to Google Drive for desktop (virtual drive G:) fails with "Failure to save the file. 'example.png' could not be saved. The remaining files will not be saved."
    What I tested:
    - Exporting to a local folder (Desktop) works fine.
    - Exporting the same frame from Figma in the browser directly to the same Google Drive folder works fine.
    - I can create files/folders in that Drive folder normally via File Explorer, and Google Drive is syncing correctly.
    - Clearing cache (Help > Troubleshooting > Clear cache and restart) did not help.
    In my case it happens in "My Drive" (G:\Meu Drive\...), not only in Shared Drives.
    Environment:
    - Figma Desktop [126.11.7]
    - Windows [11 Home / versão]
    - Google Drive for desktop (streaming mode, G:)
    This blocks my daily workflow too, since I deliver client files directly to Google Drive. Hoping for a fix soon!
    CeciliaGonçalves
    Nov 4, 2026 4:23 PM UTC
    Hello,
    Since Figma Desktop updated to version 126.11.7 (Windows), I can't export files to any folder in Google Drive for desktop (virtual drive G:). The export fails with:
    Steps to reproduce:
    2. Select a frame and export it as PNG.
    3. In the save dialog, choose a folder inside Google Drive for desktop (e.g. G:\Meu Drive\...).
    4. The export fails with the error above.
    - The folder exists and I have write permission (I can create files there via File Explorer).
    - Google Drive for desktop is syncing correctly.
    - Exporting to a local folder (Desktop) works.
    - Exporting from Figma in the browser to the same Drive folder works.
    - Controlled Folder Access is disabled.
    - Clearing the desktop app cache did not help.
    Environment:
    - Google Drive for desktop (streaming mode, mounted as G:)
    It looks related to this report from another user:
    This is a blocker for my daily workflow, since I save client deliverables directly to Google Drive. Thanks!
    ksn
    Nov 4, 2026 9:25 PM UTC
    Hi ​@rec_intra  - thank you for reporting this to us. Our support team has raised this to our engineering team, and they are currently investigating.
    I will keep you (and this topic) updated as we learn more, and also reach back out if there is additional information that we’d like to gather from you.
    ​@CeciliaGonçalves I merged over your original topic over here as well, so we can keep track of this issue in one place. Thank you as well for reporting!
    Yevhen Chuhuievets
    Nov 5, 2026 10:56 AM UTC
    Export Frames to PDF - same issue for Google Drive. Issues after the latest update.
    Maty
    Nov 5, 2026 11:44 AM UTC
    Same here! It’s annyoing as hell!
    ksn
    Nov 5, 2026 4:27 PM UTC
    Hi ​@rec_intra ​@CeciliaGonçalves ​@Yevhen Chuhuievets ​@Maty
    Our engineering team is focusing on this issue, and have requested the following information to help expedite a resolution.
    Could you please provide:
    File access
    • View-only access for any files that fail to export with  support-share@figma.com and let me know once it’s granted? This email is purely for sharing files, and only our support team will have access. You will not be charged for this.
      • Please also confirm whether we can duplicate the file for troubleshooting.
    If you cannot share the files, that’s no problem. We understand that some information is sensitive.
    Please let me know when you can!
    CeciliaGonçalves
    Nov 5, 2026 4:47 PM UTC
    Hi @ksn, thanks for looking into this!
    I've shared a test file with support-share@figma.com:
    the issue is not file-specific: exporting ANY frame from ANY file to a Google Drive for desktop folder fails in the same way...
    steps to reproduce:
    1. Select one frame and export it as PNG (1x)
    2. In the save dialog, choose any folder inside Google Drive for desktop
    4. Result: "Failure to save the file. '<filename>.png' could not be saved. The remaining files will not be saved."
    the tests i did (with other files, same export configs):
    - Export to a local folder (Desktop): works.
    - Export from Figma in the browser to the same Google Drive folder: works.
    - Creating files/folders in that Drive folder via File Explorer: works, and they sync normally.
    Important: the bug only happens when we save through the Windows "Save as" dialog (File Explorer) directly into a Google Drive for Desktop folder (G:). Saving to any local folder through the same dialog works normally.
    Happy to run any additional tests or send logs if needed. Thanks!
    ksn
    Nov 5, 2026 5:51 PM UTC
    Thank you! Going to follow up with you via PM to get some additional info.
    CeciliaGonçalves
    Nov 5, 2026 6:34 PM UTC
    hey! here is the har files with the network logs.
    thanks!
    [file redacted]
    ksn
    Nov 5, 2026 6:42 PM UTC
    Thank you! I provided them to the support team - if you have any additional attachments, please provide them in a response via the email.
    I redacted the logs you provided to protect your privacy (just want to be safe and make sure no personal data is exposed publicly).
    Дарья Зимовцева
    Nov 6, 2026 9:09 AM UTC
    I agree with the author. I’m having the same issue with exporting.
    PNG export fails when saving directly to Google Drive on Windows – Figma Desktop 126.11.7
    Hello!
    I am experiencing an issue with exporting PNG files directly to Google Drive using Figma Desktop.
    System details:
    - Figma Desktop version: 126.11.7
    - Operating system: Windows
    - Google Drive for Desktop: Stream files mode
    Issue:
    When I try to export PNG files from Figma directly to any folder on my Google Drive, the export fails with the following error:
    "Saving file failed. '[filename].png' could not be saved. Remaining files will not be saved."
    This happens with any Google Drive folder, not just a specific one.
    However, exporting files to local folders (such as Downloads) or an external drive works perfectly. I can then manually move the exported files to Google Drive without any issues.
    I have confirmed that Google Drive itself is working correctly and that I have permission to create and upload files.
    This issue seems to be related to Figma Desktop version 126.11.7, especially since other users have reported similar problems.
    Could you please investigate this issue and let me know if there is a fix or workaround?
    Thank you!
    Rodrigo Almada
    Nov 6, 2026 1:15 PM UTC
    Hello. Same problem here after the Figma Desktop Update. Please let us know if there is a workaround while the support team is working on the fix.
    Maty
    Nov 6, 2026 3:32 PM UTC
    Outside Figma, I could write to the same folder without errors. I tried a direct write, a write to a temp file followed by a rename, and overwriting an existing file. There was no existing test.png, about 228 GB was free, and the path was 60 characters.
    What a Process Monitor capture shows
    I captured Figma.exe during a failing export. The failure is the temp-file create in the target folder:
    CreateFile  Z:\...\WORK\ (1).figma-export-4b2b4040-c0a3-4c19-8df9-ac8d6567a819Result: INVALID PARAMETERDesired Access: Generic Read/Write, Delete, Write DACDisposition: OverwriteIf, Options: Sequential Access, Non-Directory FileAttributes: A, ShareMode: None
    Figma retries it twice with slightly reduced access flags. All three attempts return INVALID PARAMETER, and then the export aborts.
    Related failures at the same moment:
    • Two operations on .figma-export-4b2b4040-… in the same folder return INVALID PARAMETER.
    • SetDispositionInformationEx (FILE_DISPOSITION_DELETE | POSIX_SEMANTICS | 0x10) on that temp file returns INVALID PARAMETER. Cleanup falls back to a plain SetDispositionInformationFile, which succeeds.
    Observations
    • The temp name starts with a space, (1).figma-export-<uuid>. That looks like an empty base filename plus a de-duplication suffix, which seems wrong.
    • The create asks for Write DAC with ShareMode: None and OverwriteIf. That is an unusual set of access flags for an export temp file.
    • In the same export, the temp file in C:\Users\<user>\Downloads\<uuid>.tmp is created and written without error. Only the Google Drive target fails.
    This points to a change in how the export writes its temp file to the destination folder. Drive for Desktop’s virtual filesystem (volume label G) rejects it.
