rec_intra
Nov 4, 2026 2:37 PM UTC
PNG export fails on Google Drive for desktop after updating to 126.11.7 (Windows)
Hello,
After Figma Desktop auto-updated to version 126.11.7 (Windows), I can no longer export PNG files directly to a folder in Google Drive for desktop (virtual drive G:, a Shared Drive).
Steps to reproduce:
1. Open any file in Figma Desktop 126.11.7 on Windows.
2. Select a frame and export it as PNG (1x).
3. In the save dialog, choose a folder in Google Drive for desktop (e.g. "G:\Drives compartilhados\...").
4. The export fails with the error: "Failure to save the file. '<filename>.png' could not be saved. The remaining files will not be saved."
What I already checked:
- The destination folder exists and I have write permission (other apps save there normally).
- No file with the same name exists, the path is short (163 characters), and there is enough disk space.
- Exporting the same frame to a local folder (Desktop) works fine.
- Launching the previous version (126.10.13) still installed on my computer, the export to the same Google Drive folder works perfectly. So the problem started with version 126.11.7.
Environment:
- Figma Desktop 126.11.7 (broken) / 126.10.13 (works)
- Windows 11 Home 10.0.26200
- Google Drive for desktop (Shared Drive mounted as G:)
This is a major blocker in my daily workflow, since I export approval files directly to our shared drive. Screenshot of the error attached.
Thank you,
Renan
    CeciliaGonçalves
    Nov 4, 2026 4:21 PM UTC
    Same issue here. After Figma Desktop updated to 126.11.7, PNG export to Google Drive for desktop (virtual drive G:) fails with "Failure to save the file. 'example.png' could not be saved. The remaining files will not be saved."
    What I tested:
    - Exporting to a local folder (Desktop) works fine.
    - Exporting the same frame from Figma in the browser directly to the same Google Drive folder works fine.
    - I can create files/folders in that Drive folder normally via File Explorer, and Google Drive is syncing correctly.
    - Clearing cache (Help > Troubleshooting > Clear cache and restart) did not help.
    In my case it happens in "My Drive" (G:\Meu Drive\...), not only in Shared Drives.
    Environment:
    - Figma Desktop [126.11.7]
    - Windows [11 Home / versão]
    - Google Drive for desktop (streaming mode, G:)
    This blocks my daily workflow too, since I deliver client files directly to Google Drive. Hoping for a fix soon!
