Joshua Rauer
Mar 31, 2026 7:10 AM UTC
Plugin review status is not changing
I’m reaching out regarding the review status of a plugin I submitted called Mailsupply.
The plugin has been in review for more than 15 days now, and I wanted to ask whether this is still within the normal review timeframe or if there might be any issue with the submission.
I have not received any update yet, so I would really appreciate it if you could let me know:
• whether the plugin is still being reviewed
• whether any action is needed from my side
• and if possible, an estimated timeframe for when the review process might be completed
The plugin name is: Mailsupply
Thank you for your help.
    Celine_Solution
    Apr 2, 2026 8:18 AM UTC
    Hey ​@Joshua Rauer , your plugin has been approved. Please check your inbox, you should have received a message from the Figma team.
    Thanks again for your patience! I’ve gone ahead and closed the topic here 😊
    Mar 31, 2026 9:52 AM UTC
    Hey Joshua, Celine from the Figma Community here! Thanks for reaching out about your plugin Mailsupply.
    I checked on this and can confirm that your submission is still in the review queue. Review timelines can vary depending on submission volume and team capacity, and we’re currently seeing a higher number of submissions, which may lead to longer wait times.
    No action is needed from your side at this stage — if anything comes up during the review, the team will reach out directly via the email linked to your Figma account. In most cases, no update simply means the review is still in progress.
    While you’re waiting, it can be helpful to take a quick look at the review guidelines here, just to make sure everything is aligned:
    https://help.figma.com/hc/en-us/articles/360039958914-Plugin-and-widget-review-guidelines
    At the moment, we’re not able to provide an exact timeframe, but please know your plugin is in line for review and the team will follow up as soon as it’s been reviewed.
    Thanks again for your patience! 🙏🏼
    Joshua Rauer
    Mar 31, 2026 10:41 AM UTC
    Ok thank you!
    Celine_Solution
