Andrea SCORTI
Apr 29, 2026 12:16 PM UTC
Plugin review - 1month pending
Hello,
Any updates on the review for the plugin we want to publish “Properties & Variants Manager”?
It is a plugin to handle changes in variants / peroperties name and values, very convenient for design system designers.
A use case: A designer is publishing the design system, but didn't realize on some components she called an option for a property Size "Sm", but in other components "Small". Without the plugin, she has to manually check each component and update the property. With the plugin, she can discover more easily this problem, and as well solve it with few simple clicks.
Thank you!
Andrea - Amadeus
Gayani_S
Gayani_SSolution
Apr 29, 2026 2:57 PM UTC
Hey ​@Andrea SCORTI! First of all, this sounds like a really useful workflow improvement for design systems. Thank you for building this for the community!
I can confirm that “Properties & Variants Manager” is currently in the review queue, and there’s nothing further needed from your side right now.
The team is seeing a higher volume of submissions at the moment, which is impacting review times. I’ve flagged your plugin internally to give it a bit more visibility. The team will reach out as soon as there’s an update, whether that’s approval or feedback. Thanks again for your patience while this moves through the process!
Gayani_S
Gayani_SSolution
