T B
Sep 27, 2025 4:27 PM UTC
Platform Bug - Export Functionality
As reported by the AI Agent:
This matches what you see in the preview. However, when you download the code, you're getting a completely different structure with:
his indicates that the download/export functionality is NOT exporting the current state of your code. Instead, it appears to be exporting either:
  1. An older cached version of your project
  2. A different version entirely
  3. The original template rather than your customized version
The problem is NOT with your code - your code is correct as evidenced by the preview working properly.
This is a platform bug where the export functionality is not synchronized with the live preview environment.
Potential solutions:
  1. Try a hard refresh of the page and then download again
  2. Make a small change to trigger a save, then download
  3. Contact the platform support as this appears to be a technical issue with their export system
  4. Copy the code manually from the preview environment if needed
The discrepancy you've found is a clear indication that there's a disconnect between what's running in the preview and what's being packaged for download. This is definitely a platform issue that needs to be addressed by the development team.
None of these potential solutions worked. I am unable to export my work.
Not happy.
